Import Monster Sauvic Deca Motorkhana - 2012 Round 1
Proudly Presents:
Import Monster SAU-Vic DECA Motorkhana ROUND 1 of 4 of the 2012 DECA CHAMPIONSHIP
When : Saturday 25th February 2012
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. HERE!!!
NO PAYMENT, YOU WILL NOT BE ON THE LIST
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Ryan Bell Disclaimer'.
Event Schedule:Here
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 20th February.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
  • Replies 378
Entry List:
1. Ash Cosgriff R33 GTR
2. Import Monster
3. Leon Stapley 180sx
4. Ryan Bell 180sx
5. Ashley Stacey R33 GTR
6. Luke Schulze R33 GTS-t
7. Trung Nguyen Chaser
8. Chris Taylor 300zx
9. Daniel Taylor S14
10. Harsh Gupta R33 GTR
11. Bradly Insley XR6
12. Mark Ryan R33 GTS-t
13. Hamish Hampton R33 GTS-t
14. Clive Small Lancer
15. Jake Lowry S14
16. Paul Stephenson EVO VII
17. Kat Glebova EVO VII
18. Mario West EVO VIII
19. Jett Benson 180SX
20. Simon Henman R33 GTS-t
21. Gary Swift 180sx
22. Sandeep Abeywickrema 300zx
23. Alex Skrekovski EVO X
24. Steven Skrekovski MX5
25. Russell Cunningham R32 GTS-t
26. Jordan Sudarevic MX5
27. Ryan Gorzella RX8
28. Rhys Cantrill R33 GTS-t
29. Daegal Harris S14
30. Johnathon Oliver VX
31. Jakub Radzikowski 180sx
32. Brad Archbold Evo VIII
33. Thai Long Chieu Corona
34. Jad Luciani R33 GTS-t
35. Matthew Nisi S14
36. Daniel Somerville STI
37. Andy Theobald GSR
38. John Packham S14
39. Elvis Ayala R33 GTS-t
40. Laith Graham R33 GTS-t
41. Brendon Pryor R33 GTS-t
42. Damien Nebel STI
43. Mark Rodgers STI
44.
45.
46.
47.
48.
49.
50.
Reserve:
1.
2.
3.
4.
5.
Can I enter in a Daihatsu Terios? It's designed extra narrow so it can fit down certain streets in Japan, combine that with its high center of mass and it'll be great on the skidpan! Lets not forget the 65kw at the fly + AWD for some limiter launches!
gonna shoot some money through and my entry tomorrow or monday :)
i hope the NA can actually do something haha
N/A's kill it on the skid pan.... soooooo much easier than high HP cars
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
