Import Monster Sauvic Deca Motorkhana - 2012 Round 1
  • Replies 378
Thanks for the persuasion from Russ, Leon and a couple others (Sorry, I'm shit with remembering names!), I reckon I'll be in on this.
Just working out my plans, but reckon I should have an entry form in early this week.
My first DECA here we come!
You wont regret it....
....well unless you break something :whistling:
But seriously now, it is a great event, and the guys/girls in the club are mostly awesome and dont bite! look forward to meeting you!
f**k i broke my car :( clutch kicked first, hit limiter and it made a real loud bang... now the 4th cylinder is doing nothing... think it could be snapped rocker arm stopper or lifter... it better be fixed for decccaa!!!!!
rocker arms easy fix,
and suggest one of these:
http://www.gktech.com.au/product_detail.asp?id=SR20-RASK
during replacement, put one in for safety sake i've bounced limiter soo many times since and no worries
Is it possible to sign up on the day?
I have an AASA licence but I think I want to spectate for a while first to figure out whats going on
We dont usually do sign ups on the day - but I will let Bec/Leon/Ryan make that call, I guess it depends on numbers etc and if there are any spots left.
Hey Antz,
Just realised you live literally 15 mins away from Luke (NUTR33) and I. Definately enter if you can. It is a great day and you will meet some really nice guys and gals. Dont stress too much about not having done it before - we have all been the first timer at one stage! Its not overly hard, and there are maps and demos/indian file runs so you can see what to do.
I promise we dont bite!
Cheers, Anna
Just request to be put in the middle/at the end of the group so you can watch others go first. You'll pick it up really quickly. And don't feel pressured to give it 100%, go out there to have some fun and you'll be wanting to come back again. And if you have any questions, everyone is friendly and willing to help you :)
Ya got me convinced! :thumbsup:
Just gotta look into accommodation.
Is there any place in particular that SAU'ers stay, or just any old hotel?
I'm always keen hang back n talk sh*t reminiscing after the day!
http://www.skylinesaustralia.com/forums/topic/389069-deca-accommodation-24-25-feb/
:thumbsup:
Well I dont have access to a printer/scanner/fax so short of snail mail I can't return the sign up sheet.
Anna, I knew Id seen that wagon somewhere haha, but I have since moved to Melbourne.
Unrelated: Anyone going to winton this weekend?
You friggin champion! just put my name down for both nights.
My entry form will be in in the next couple days! :thumbsup:
Go to a Library, print it out, fill it out and fax it through. :thumbsup:
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
