Import Monster Sauvic Deca Motorkhana - 2012 Round 1
  • Replies 378
Thanks for the persuasion from Russ, Leon and a couple others (Sorry, I'm shit with remembering names!), I reckon I'll be in on this.
Just working out my plans, but reckon I should have an entry form in early this week.
My first DECA here we come!
You wont regret it....
....well unless you break something :whistling:
But seriously now, it is a great event, and the guys/girls in the club are mostly awesome and dont bite! look forward to meeting you!
f**k i broke my car :( clutch kicked first, hit limiter and it made a real loud bang... now the 4th cylinder is doing nothing... think it could be snapped rocker arm stopper or lifter... it better be fixed for decccaa!!!!!
rocker arms easy fix,
and suggest one of these:
http://www.gktech.com.au/product_detail.asp?id=SR20-RASK
during replacement, put one in for safety sake i've bounced limiter soo many times since and no worries
Is it possible to sign up on the day?
I have an AASA licence but I think I want to spectate for a while first to figure out whats going on
We dont usually do sign ups on the day - but I will let Bec/Leon/Ryan make that call, I guess it depends on numbers etc and if there are any spots left.
Hey Antz,
Just realised you live literally 15 mins away from Luke (NUTR33) and I. Definately enter if you can. It is a great day and you will meet some really nice guys and gals. Dont stress too much about not having done it before - we have all been the first timer at one stage! Its not overly hard, and there are maps and demos/indian file runs so you can see what to do.
I promise we dont bite!
Cheers, Anna
Just request to be put in the middle/at the end of the group so you can watch others go first. You'll pick it up really quickly. And don't feel pressured to give it 100%, go out there to have some fun and you'll be wanting to come back again. And if you have any questions, everyone is friendly and willing to help you :)
Ya got me convinced! :thumbsup:
Just gotta look into accommodation.
Is there any place in particular that SAU'ers stay, or just any old hotel?
I'm always keen hang back n talk sh*t reminiscing after the day!
http://www.skylinesaustralia.com/forums/topic/389069-deca-accommodation-24-25-feb/
:thumbsup:
Well I dont have access to a printer/scanner/fax so short of snail mail I can't return the sign up sheet.
Anna, I knew Id seen that wagon somewhere haha, but I have since moved to Melbourne.
Unrelated: Anyone going to winton this weekend?
You friggin champion! just put my name down for both nights.
My entry form will be in in the next couple days! :thumbsup:
Go to a Library, print it out, fill it out and fax it through. :thumbsup:
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
