Import Monster Sauvic Deca Motorkhana - 2012 Round 1
People might laugh but these rules exist for a very good reason and they're really not hard to follow at all :)
It seems like common sense to me... ...But that being said... ...I'm really worried that I'll miss something and not get to take part...
  • Replies 378
You will be fine. Just use the supp regs as a guide and make sure you dont leave anything at home ;)
Looking forward to this. Leon has kindly offered a drive in the orange beast.. should be good!
Thanks Russ. You have all been given plenty of notice :thumbsup: On that, please do your best to be on time. The earlier we can get on track the more runs you get in the arvo ;)
I'm in. Been a while but it's just like riding a bike right? Except I'm in a car... Ahwell, I'll just stick to my old ways. When in doubt... Burn out.
See you all soon!
Reppin for the North East (f**k Campbell).
Least Campbell would probably stick around for drinks and partying and not wussy off home :nyaanyaa:
What the hell is wrong with your car these days? If it needs tyres then I can help with those...lol I need a car to drive :( Actually, I need someone to drive my car up from Melbourne...
Are you just coming down from Yarrawonga?
BAHAHA!
Good to see you're coming Brendan.
Could maybe help Troy...although if my car is good to go then I cant help...im sure something else will come up and prevent me from getting it back but fingers crossed.
On another note everyone knows that you can never do well at deca if you dont drink Friday and Saturday nights, and party until the early hours of Sunday.
whoever is getting footage of the day needs to make a video like this :D
http://www.youtube.com/watch?v=rI5_KugDtAE
I'm working on getting better video skillz for things like this...
LOVE low/wide/flush/black S13's... although preferably with bumpers! Haha
Loving some of the 4WD slides... ei, the Black Subi at around 30 seconds.
Itching for Friday night to come round! Although weather app says Saturday is 35 degrees and possible thunderstorms! :huh:
Troy: time to be number 2 driver. Mix things up a bit in something else..
Oh, and we've 'employed' some 'professionals' to do some interviews around the traps at this deca... look out :whistling:
Kieran, do it.
I was just about to email through my application and noticed that it says entries close on yesterday at 10pm.
if I send through the form today and Direct Deposit the funds today is that still okay? Or have I missed the boat on this one?
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
