Import Monster Sauvic Deca Motorkhana - 2012 Round 1
So I just filled out the form, and also my AASA renewal form,
do you recommend that I wait for my AASA to come back before i fax the form off to you guys? or can I send it off now and fill in AASA details later?
  • Replies 378
I've done a few, maybe 5 or 6 now, but I've never seen another zed out there. Mine was a non-turbo but I converted it to twin turbo last year so this is my first DECA with the new engine, I'll be learning to drive the car again pretty much.
Iv been twice in mine, I thought I was the only one lol, yours turbo ?
Fax the entry form off now, and put "TBA" in the AASA number field, and fill out the details on the day, just make SURE you have the information before DECA or you'll have to "sign up" on the day (including repayment) to compete.
I THINK is the way it works...
Aww dam was hoping it was n/a mines non turbo, will be a good challenge though :P
this was me back in the day lol Edited by Chris_CCRUZE
fingers crossed for my first ever wet deca...
you want a dry deca,:thumbsup:
a wet deca sucks soooo much its almost not worth doing it
if its wet its like trying to drive on ice, just dosent work
if you jynx it then there will be some really unhappy people :laugh:... but :mellow:
YEESSSS jakeeee!!! Although I just found out I can only run like 9psi through the new high mount turbo untill I tune it again and I'm not gonna do that untill I get the new computer and injectors and rah rah rag so I won't be that quick :(
what high mount you got?
response is better for deca anyways :thumbsup:
Sussing out s15 injectors and tuning it at 13-14psi before deca so Deffs battle ;)
might have a good battle if you get it tuned, ive got a guestimated 180rwkw.ish but pretty responsive
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
