Import Monster Sauvic Deca Motorkhana - 2012 Round 1
  • Replies 378
So leons finishing up the event sched as we speak... Good work leon ;) looks like we are going to run the mega mini wang again!
Looks like we are having a slow filling deca so its time for everyone to get on the horn and recruit some friends.. I think its also time for some motivational vids so lets make this thread a little more interesting by putting up your favourite deca vids ;)
Ill start with a little of Laiths handywork from last year:
and martins
Good work Paul, good to see you and the missus are up for it again!
Technically you do not need a club membership to get a AASA licence but we encourage people to sign up to sau ;)
Licences can be sorted on the day, easy as.
Fk Fk Fk Fkkkkkk....
I need a tune badly because of my new wastegate but Trent / Status / Chequered are moving locations at the moment and won't be up and dyno'ing again until the 20th :O
Think I might miss GOR (how hard is it normally run? I'm happilly drivable but don't want to push hard), but should be right for a thrashing for DECA :wacko:
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
