  • Replies 102
Congrats Leech. You did buy a very nice car. We do belive it realy is a grade 4.5 but it was a tuff Auction and it only got a 4. Most of the cars in here wouldnt be this good of condition. We belive it will be here in 3 weeks time and only a couple of weeks after it should be complied. I hope you are still happy with your car.
Someone told me you had posted this up on the net so I thought Id have a look.
Regards Zac.
hehe thanks all and yea zac i am heaps happy with it ultimatly as you know i would like to have paid a little less but thats cause i am a tight arse lol as the when you told me the price i was like :) a bit more than what i wanted but now i am thinking i dont mind paying the little extra if its exactly what i want which it seems to be so WOOT for me and my new car hehe hopefully will have it not to long...
again great job to svi so far :) they have done everything right and put up with my constant annoying calls.
also thanks to all the nice comments appreciate them :)
yea aurora damn it i was doing alright till they sent me these pictures now i am like skyline skyline skyline haha damn it and yea kamikaze it does have ABS not sure about a boost controller looks more like a turbo timer to me actually after looking at it again.
Car looks very tidy mate! Congrats on getting a black Series II. Nice cars :D Can't wait till i get mine, but i got it a bit worse, i don't get to drive mine till late november :P. Ah well, least it'll be in the garage to drool over.
Very nice indeed though!
My mum wishes she'd helped me pay for my car so she could drive it more, she loves it, no shit, grabs for the keys first chance she gets. Which is pretty cool, cause she's buying me Injectors and a fuel pump for my 21st. Going to have to re-spray my car soon, it was almost unique once upon a time, now there'll be 4 black series 2's about. Best looking colour, but a PAIN to keep clean, wait and see guys :)
Tell your Mum to throw caution to wind and BUY a Skyline....
I did!!!!!
Opposite happens with me - my 18yo son is always comin' up with excuses to take mine out for a drive. 16 yo daughter already thinks she will be getting driving lessons in the Skyline - I think NOT......
Way coolest Mum - I often get that :);)
im still yet to see another black series II in the flesh, so to speak. Im south side, rarely even see series II's out here full stop. Ah well. and my mum already wants to take my car out for a spin even tho i dont have it yet :)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
