  • Replies 102
Wow, you're car looks great, almost exactly the same as mine only mine doesn't have all the badging and stuff on it (to be thruthful im glad, didn't want some dick trying to get the S logo off the bonnet with a screwdriver :bonk: )
As for my baby :) booked in for rego on Thursday, should pick it up next weekend if all goes well. I'm all psyched up now! :)
Anyways, good luck with it, that's one nice looking car!
lol we will probably be on the road at the same time maybe you a couple of weeks earlier :) yea the badge on the bonnet will come off ASAP looks a bit homo on that note any tips people that have removed it is it glued on or does it have some sort of bolt/attachement.
yea i would see if i do want it in the end but i was thinking POSSIBLY i dont know how it would look yet but see if it would mount between the bonnet and the bart like were people ahve their GT-R one i could just put that S... not sure if it would look dicky or not but we will see hopefully it looks good
  • 3 weeks later...
well the car arrived today took it for a quick spin around the block mmm turbo's are nice. other than that it needs a really good clean and a bit of cut and polish and it will be sweet as. Goes into rego on thursday and seeing as how it is stock as a rock it should have no problems. also tested all power options eg indicators, break lights, mirrors windows etc etc all work fine so yea i may actually get spotted soon WOOT. hope to catch up with some of you soon.. FINALLY :wassup:
Nice work mate! Took delivery of mine yesterday too. Went for a spin around Manuka...i wasn't driving cause i don't get to till november but it's still a great car to be a pasenger in. Picked up rego for mine as well, the last 3 digits are 33M :)
yeah, lets see, i got the custom plates sheet here (i wanted GAJ 33T but it cost about $1,800!!!!) the example RH 351 costs $313 for tin and $399 for plastic, unique plates (like GAJ 33T) are $1,894... if it looks like a manufacturer or model (e.g Ni55an) that's $3,531 and numeric plates go from $627 to $4,602
Almost forgot, plates with your name on them with seven or less characters cost $627.
I just ended up getting standard plates, but the lady at the motor registery Gaye was really nice and after seeing the number combo i wanted went and found plates with the numbers 33 in them. 33M or 33C... i went for M.
About the plates, i noticed the standards fit just fine in the rear bracket, but at the front they're a few centimetres too long and had to be bent to fit in the mounting brackets. It looks pretty crappy. Is it possible to get a smaller plate for the front and how much would i be looking at for that? I want to keep it blue + white like the standard plate on the back too.
on the R32 the plates dont fit at all without bending, so the front i moved to the side and the rears bent, not much can be done about it
good to see the two of you will both be on the road soon,
Kinda yes....but what would they prefer? no plates at all? :D
When i get around to ordering a plastic replacement for my tin ones, i'll whip up a bracket to side mount it. Give more flow to what's left of my intercooler, and looks good too :) Brake ducting...who needs brake ducting...i've got a great big stainless pipe there for the intercooler anyway
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
