Exactly. Fit them in or on the car how you can, and if someone has a problem with it, well, look into fixing it then, but til then, live it up with bent/cut/whatever plates.
I know it's not right, but as i said, it's better than having no plates on the car at all. And unless you get someone who is trying to enforce the law down to the letter, you're usually pretty okay with them as long as they are on the front, and back, and pretty visible.
  • Replies 102
WOOT well went back for the ID check only to be told that i dont need an ID check ??? oh well saved me some time. Then i gave them the paper showing the weight of the car. he then asked for my papers again which i had given them earlier in the day. i informed him i didnt have them as i gave them to one of the staff this morning he did find them after 10 minutes of searching so i wasent to fussed. so its all approved i now just need to get rego and some plates ;) WOOT
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
