  • Replies 102
Congrats Leech. You did buy a very nice car. We do belive it realy is a grade 4.5 but it was a tuff Auction and it only got a 4. Most of the cars in here wouldnt be this good of condition. We belive it will be here in 3 weeks time and only a couple of weeks after it should be complied. I hope you are still happy with your car.
Someone told me you had posted this up on the net so I thought Id have a look.
Regards Zac.
hehe thanks all and yea zac i am heaps happy with it ultimatly as you know i would like to have paid a little less but thats cause i am a tight arse lol as the when you told me the price i was like :) a bit more than what i wanted but now i am thinking i dont mind paying the little extra if its exactly what i want which it seems to be so WOOT for me and my new car hehe hopefully will have it not to long...
again great job to svi so far :) they have done everything right and put up with my constant annoying calls.
also thanks to all the nice comments appreciate them :)
yea aurora damn it i was doing alright till they sent me these pictures now i am like skyline skyline skyline haha damn it and yea kamikaze it does have ABS not sure about a boost controller looks more like a turbo timer to me actually after looking at it again.
Car looks very tidy mate! Congrats on getting a black Series II. Nice cars :D Can't wait till i get mine, but i got it a bit worse, i don't get to drive mine till late november :P. Ah well, least it'll be in the garage to drool over.
Very nice indeed though!
My mum wishes she'd helped me pay for my car so she could drive it more, she loves it, no shit, grabs for the keys first chance she gets. Which is pretty cool, cause she's buying me Injectors and a fuel pump for my 21st. Going to have to re-spray my car soon, it was almost unique once upon a time, now there'll be 4 black series 2's about. Best looking colour, but a PAIN to keep clean, wait and see guys :)
Tell your Mum to throw caution to wind and BUY a Skyline....
I did!!!!!
Opposite happens with me - my 18yo son is always comin' up with excuses to take mine out for a drive. 16 yo daughter already thinks she will be getting driving lessons in the Skyline - I think NOT......
Way coolest Mum - I often get that :);)
im still yet to see another black series II in the flesh, so to speak. Im south side, rarely even see series II's out here full stop. Ah well. and my mum already wants to take my car out for a spin even tho i dont have it yet :)
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
