Ok, i did a quick search for the same problem, but i couldn't find anything.
I have an odd ticking noise coming from my engine bay, it's irregular, and only happens when im idling. it's coming from the drivers side of the engine bay. i'm fairly certain i have a dodgy AFM, and my only theory is that it's playing havok with the injectors so they're turning on and off randomly or whatever injectors do at idle. the idle does jump around slightly, between 700 and 1200, but usually sits around 700 - 800. it goes away as soon as i rev it and never happens while driving. is there anything serious that could go make that noise on that side of the car? it's sort of like an electronic ticking like a solenoid going spastic.
anywho, any help appreciated.
https://www.sau.com.au/forums/topic/38937-random-ticking-noise-in-engine-bay/
nah oil is fine, it's an electrical ticking noise, like a solenoid clikcing on and off at random intervals. whenever my idle is playing up is when it happens. if the idle is being a good boy on that day it won't do it. that's what led me to believe possible injector problem.
Interesting... I had a ticking noise., but it happened all the time... I found it out to be the electric window switch was playing up, when i put my window down, the switch would stay partly on, and it would tick (ie a solenoid). I've figured out aslong as i make sure the switch is off after i put my window down its fine... Probably not wat ur problem is, but thought it was worth a mention.
one solinoid that is fairly loud is the vvt solinoid which comes on as soon as there is movement of the throttle, your tps (throttle position sensor) could be dodgy and kicking the vvt solinoid in and out.
just a thought
this sounds like my problem, thanks dude. i'll have to get my TPS checked out.
If you have a dodgy AFM then there's a fair chance the idle's jumped because the ECU's in limp mode. Dodgy TPS shouldn't cause the idle to jump - I think the ECU resets its throttle reading when you start the car, ie it makes whatever it's reading then as 0% throttle.
I have the exact same ticking noise on my car. It's a worn lash adjuster. Nothing to worry about, just annoying. The reason it only ticks at or near idle is because that's when oil pressure is at its lowest, and if the adjuster is worn it'll return the oil more quickly than it should and so 'bleeds' itself. Think about trying to blow up a balloon with a small hole in it. If you only blow a little bit, it will stay flat. It you blow harder, so that you're putting in more air than the hole is letting out, the balloon will stay inflated.
Different oil doesn't fix it - well maybe something like 80W90 would, but that's not a good idea :rant:
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
