C63 Owner About To Testdrive Gtr Needing Help
Yep transmission temperature management is important on track to avoid excessive costs if you plan to keep your warranty and you learn to watch it constantly on track.
Pre-track inspection is not necessary to maintain warranty and I just have the suspension settings left in the track settings as I don't drive the car much anyway and the outside of the tyres always wear first.
The post-track inspection seems to be a genuine inspection too, the dealer replaced a headlight and brake caliper under warranty on the last one.
I still think it is flawed logic though to ignore a car purely because it has been on track, I mean from the last couple of GTR track days I have been on, "on track" can mean anything from the guy who loaned his GTR to the Top Gear tour crew which did Stig hot laps for 3 hours or the middle-aged gentlemen who puttered around in the middle of the track for 20 minutes in the morning.
Certainly looks like there are plenty of garage queen GTRs around though!
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
