]Hi Guys for sale
Fs. 4 inch drift cannon brand new never been fitted to a car
sell for $200 ono
R33 M-spec Front bar $300
R33 D wing $200
Edited by MAD R33
do you have an estimate how much it would cost to deliver that drift wing to Tasmania? or at least measurements so I can work it out as I would like to buy the wing off you
Nismo cannon $150
brand new Drift cannon $100
big Drift wing $250
rear springs $90
front right side spring $60
front left side spring only. $30
R33 dash $25
R33 back light cover $15
cross over pipe for intercooler piping $20
R33 wipers a set of 3 $25
brand new wheel $30
stock plenum with out water pipe and with A/C just plenum only $30
rear back cover that says skyline go's under the boot $10 needs a paint job
inside boot carpet that hides the light wiring $15
R33 S1 turbo no shift play runs well only done 85kms $200
Edited by MAD R33
can you send me pics of the big drift wing, and how much is shipping for the smaller d wing or the big drift wing to Coffs Harbour 2450?
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
