There is a thing called:
Brake specific fuel consumption (BSFC)
It's a figure to describe how much fuel an engine needs to produce X amounts of power.
http://www.land-and-sea.com/dyno-tech-talk/using_bsfc.htm
There is a calculator on this page ->
http://www.rceng.com/technical.aspx
My (standard) injectors are now at 85% duty cycle, I am making about 330HP at the crank. (running at AFR of 11.7)
The mixture was starting to lean out already, so I have ordered new injectors.
Edited by Torques
From my personal experience the standard injectors can hold more than most think. As my 33 gtst is making 393hp@wheels on standard injectors...
For the dyno figure doubters it does 119mph down quarter..
Edited by fragz013
My (standard) injectors are now at 85% duty cycle, I am making about 330HP at the crank. (running at AFR of 11.7) The mixture was starting to lean out already, so I have ordered new injectors.
Hmmm if you are finding that the fuel flow into the engine is levelling off at 85% IDC I'd consider looking at whats supplying fuel to the injectors more than the injectors themselves, personally - what pump is that with?
almost 300 rwkw? doubtful
119mph isn't a bad trap speed though, to be fair... though in saying that when you are limited by small injectors you can still make a car quite a bit faster than many would expect doing sneaky wee tricks. At lower rpm you have a longer pulse period, so you can actually move more fuel with an equivalent duty cycle.
As an example - I've tuned a Silvia running a G4 Link & boost control but still on stock injectors was quite held back, hitting 85% at 7000rpm at the boost level we were setting it up for. That boost level just wasn't going to do the setup justice, so I set up a "tapering" boost curve which resulted in a boost level some 6-7psi higher at 4500rpm than at redline and progessively dropping down... but injector duty cycles still never went over 85%. The resulting change in how the car performs is VERY substantial, torque wins races and hp sells cars?
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
