Thought this might be a useful topic as so many people modding stock 25's are shooting for 300kw these days.
With this power level constantly in debate, lets get some stats...
use this formula:
mods:
fuel:
power:
oil:
useage:
lifespan:
failure:
comments:
Unopened 25's only pls
kgo...
https://www.sau.com.au/forums/topic/389417-300kw-unopened-25-club/
I'll start the ball rolling:
engine 1 - R33 s1 RB25DET - 250,000km
mods: HKS GT2835 Pro S, 555cc injectors, fmic, custom CAI, atmo catchcan, other non related mods
fuel: bp ultimate / manildra e85
power: 280rwkw / 325rwkw
oil: motul 4100 turbolight 10w40
useage: daily /light trackwork
lifespan: 3 years
failure: spun bigend bearing
comments: motor also ran 185rwkw for about 5 years prior and was from a car that was tracked in japan as far as I can tell. motor had a very hard life.
engine 2 - Stagea 25 - modded for rwd - s2 RB25DET - 70,000km
power: 290rwkw / 325rwkw
oil: castrol edge 10w60 (98 ron) / motul 6100 15w50 (E85)
lifespan: new motor - was stock power in an auto stag till now
failure: n/a
comments: New motor has a bigger sump (26 block) and is being run on heavier oil. Tuner is same and bolton's are same. So far it is more responsive, more powerful and everything is looking positive.
  • Like 1
engine mods: Turbo conversion, GT3076r, Tial 44mm gate + screamer, Nismo 740 injectors, Power Fc + Comm,TurboSmart Bov, Exhaust cam gear, other support mods - read sig for rest
fuel: shell v-max (98)
power: 284rwkw 18psi / 21psi? 3xx?
oil: motul 8100 100% synthetic
useage: daily/cruises very light track work
lifespan: nearly 6 years (200,000km)
failure: standard servicing parts, of recent - water pump leak, internally, block has never been touched
comments: in my possession motor ran: 104rwkw - 1 year, 180rwkw - 1 year, 230rwkw - 2 years, 284rwkw - nearly 2 years so far
good idea Hamish!
mods: RB25DETneo, 6boost high mount, GT3540, Turbo smart 50mm wastegate & screamer Splitfire coilpacks, HKS fuel rail & 680cc injectors, front entry intake plenum, Power FC
fuel: BP Ultimate + Octane booster as a safety net
power: 330rwkw @ 19psi, mid to high 200's @ 14psi
useage:occasional street driving, light track work
lifespan: been at least 3 years but would have been lucky to cover 2000km in that time
failure: none but the tyres don't like it, lol
comments: motor had 34,000kms when I got it 6 or so years ago, ran at 200rwkw on stock turbo until upgrade.
  • Like 1
mods:s2 rb25det 140,000km, usual bolt ons z32 nismo 555 etc, nismo intank pump with 044 surge tank feed, hypergear tr43i turbo
fuel: caltex e85
power:307kw 17psi
oil:motul 4100 power
useage: track drift car
lifespan:2 years and still going
failure: not yet
comments: seems to be strong motor ran 2 years about 200kw, 1 year 270kw prior to this setup when was daily. Has survived a couple of track days with faulty CAS making it run lean at around mid 14s and no problems.
mods: gt3076 .82 IW, nismo 555s, 044 etc
fuel: bp98
power: at a guess 280-300rwkw
oil: usually hpr5
useage: almost every weekend with a couple of failed trackdays
lifespan: 2 yrs at over 250rwkw
failure: n/a, pulled it out to go 30det
comments:Motor never made as much power as others seamed to but never let me down, copped up to 25psi and a lot of knock along the way as i was learning to tune it myself. copped a fair bit of limiter abuse, oil pump is still going fine now on the 30. also ran for a week with a dud fuel reg and was leaning out to 15:1 under full load. when pulled down the pistons had very slight det damage but bottom end is otherwise perfect and will probably be used again when i eventually sell it.
  • Like 1
mods: R33 Series 2 RB25DET, Internally gated .82a/r GT3076R, Splitfire coilpacks, Nismo 555cc Injectors, Walbro 500hp fuel pump, GTS Link ECU, 600x300x76 generic intercooler, Trust PEII Exhaust, custom dump pipe and intake/intercooler piping, 4" K&N pod filter.
fuel: Mobil Synergy 8000 (E10) and BP Ultimate at different times
power: 270kw in 2006-2009, 301kw @ hubs at 17-18psi highest in early 2009, ranged from 284rwkw (lowest reading after raising boost to 17psi, on a rolling road dyno similar to DD) up to that highest figure depending on dyno, boost and day
useage: Occasional street driving, light track work and some drags
lifespan: Installed GT3076R and first tune for 270kw at ~100,000km in 2006
failure: No failure - stripped big turbo etc from motor just before 200,000km as I felt like time for a change and had someone keen to buy my old turbo, injectors etc in mid 2011. Motor is still running fine with a stock turbo back on it.
comments: Motor had 61,000kms when I got it 8 or so years ago, ran at 200rwkw on stock turbo until upgrade at 100,000km.
mods: R33 Series 2 RB25DET, Internally gated .82a/r GT3076R @ 17/18psi, Splitfire coilpacks, Nismo 555cc Injectors, Walbro 500hp fuel pump, Link G4 GTS/GTR ECU, Blitz LM FMIC, HKS Hi-Power Silent Exhaust, custom downpipe, 4inch intake, Simota 4inch pod
power: 285rwkw on a dyno with a dodgy wideband. Maxxed out the injectors. Retuned to more sensible Duty's and felt quite a healthy increase of butt dyno power, yet to re-dyno so will update soon.
useage: daily driven, and driven relatively hard. and regularly tracked
oil: Royal Purple 10w40 with royal purple oil filters and Mocal 13row oil cooler.
lifespan: Still going strong. No oil usage or dodgy sounds.
failure: squeaky brakes
comments: bought @ 47,000km stock, modded to 200rkw, tracked hard. Installed GT30 @ 80,000km, (87,000km now) still tracked hard.
I guess its a good indication to Garrett's turbos too. Over 100,000km on two cars that arent driven like nanas ever.
Edited by gotRICE?
Poke poke poke....
I want this thread to thrive! I want to get the Stag to 300kwatw, so this thread delivers.
I'm really only lacking turbo and injectors but don't know whether to go the 3071 (unlikely but would love the response) 3076 (likely) or HG G3 or SS2? (i think?[quite possible]).
I'm forever switching and changing so I'll be watching this thread with interest.
Edited by Cowboy1600
Interest! Interest! Yep watching this with interest, the only thing stopping me from the Kando is I have to go external gate - all the hassles of plumbing and I already got my neww JJR front/dump fitted, which will need to have the dump modified if I do go Kando... And 'jet something' mentioned a link (in another Garret turbo thread) from the US where u can get the GT3076R delivered for $1300...A superior product cheaper than a Hypergear..?? Good to go
mods: S1 RB25 from R33, Kinugawa/Kando T67, 6boost, Tial 44mm MVR, Freddy plenum, Deatchwerks 720cc injectors, 044 in tank, china cooler, z32 afm, nistune, VH45 throttle body
fuel: BP98 mixed with CSR E85 50% = E42
power: 410rwkw (hub dyno) or 360rwkw (Dyno Dynamics roller)
oil: Castrol Edge 10-60
useage: Track days, drags and light street
lifespan: Over a year so far
failure: Still going strong
comments: Cams soon for more power :thumbsup:
Edited by SimonR32
engine.. rb25det series 1... clock 221,000km
turbo ;;; gt3040 or 82 as u like... high mount 6 boost mani,external wastegate, 44 mm tial,,, no plumbak,,, 555sard injectors, bosch 500hp pump, greddy intake, greddy intercooler, z32, very very thick raditor to cool down.... :cheers:
fuel 98octane shell
tuned by trent, chequered tunning
faliure none.. running for 5 years
power 325rwkw all year around.... cheers..
mods:Link G4,7bar map sensor (dodgey atm) splitfires,HKS exhaust cam gear, K&N pod filter, CAI, FMIC,full 3' exhaust venom cat,850cc PE injectors,tomei in tank pump, Garrett GTX3071R .82 rear
fuel:Caltex E flex
power:Currently 307rwkw @ 18psi E Flex (more boost coming when map sensor is swapped)
288rwkw @ 21psi on 98
oil:AMSOIL 10W40
useage: FUN!:banana: :banana: :banana:
lifespan: Ummmm still going strong :thumbsup:
failure:N/A
comments S2 RB25DET 113000km Gunna pump as much boost as the GTX can blow efficiently and hopefully the fuel system can keep up
I tried to work it out off that website but kept getting a similar $ figure to what i paid for mine anyway.... Anyway, my car will be in this thread as soon as the tune is done :thumbsup:
mods:S1 rb25det 116,000km, z32 afm, Hypergear SS2 turbo, 650cc injectors, cooler, exhaust, hard intake pipe.
fuel: BP Pump 98
power:307kw 19psi
oil:Motul Turbo light
useage: Daily
lifespan:about a year, still going strong.
failure: coil packes burnt, changed over to split fires, no problems.
comments: Excellent on road and fast daily.
    • Hey guys, Just thought it might be of interest to owners of the RB25 det NEO motor, that awesomeness Nitto are in the late process to produce an engine gasket kit by end of Jan 25.  I think obviously there will be an 25det kit too. cheers, Ian
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
