if you dont make it then just have the tuner create a good graph and claim it to be your own, thats my plan ;)
No cheating ya goose :P And you'll be fine with your setup
I wanna join :(
Fingers crossed the SS1PU can push me into the 300's with WMI or E70
I'm only just in the club at the moment as I'm on gate pressure :(
Anyone had Err 100 on a HKS EVC before? Seems to happen every time I give it a thrashing so I've switched it off :/
Yes, yes it is. Either that or it's the tune.
There are only two factors really, but im guessing it's a foot problem.
And my figures quoted earlier - that wasn't using the O2 sensor. That was with it disabled and the tune adjusted to suit.
or sensors are broken
if the sensors are f**ked (reading lean) the ecu reverts to the base fuel map, so if that's tuned properly you shouldn't get bad economy from busted sensors. The ecu only uses the o2 sensors to trim fuel on cruise, it'll never add more fuel than the base map.
Unless the sensors are telling the ecu its running lean so it adds fuel.
I have seen it alot. Unplugging the sensors then helps with fuel economy
DVS Tuning helped me
Join this club today .
At this point in time my 34 gtt sedan is making 353kw on eflex but howevet running out of fuel
Tune soon to be 100% completed once fuel system is upgraded again.
What if the coolant temp sensor is broken and constantly tells the ECU it is cold so it runs fuel enrichment and ignition retard? Definitely make a big difference to fuel economy!
Lol 34geeteetee I'm pretty sure err 100 is an open circuit. To test that have the car running at a time the Evc is working fine then unplug the solenoid. If it gives the same error thhen that means open circuit.
it would be doing.that when its hot coz the heat makes it expand and It must have a dry or cracked solder joint inside. Make sure it is far.from.the. exhaust and that the solenoid barbs point directly skyward.
also why.does it Sig say 360kw but u keep saying its in the process and are up to 300 odd? 2nd tune?
Thanks mate... Will hopefully get it sorted before Texi...
360kw was the highest run... It was run @ 357kw on the final tune for safety... The reason for the different power figures is the 3 boost levels and also the % of ethanol.... My power ranges from 311kw to 357kw depending in boost and E content :)
Hope that makes sense?
Duno what it is mate, its pretty f*ked getting 19-20L/100kms, will definitey have that issue addressed in the tune when I do a turbo upgrade/ tune. My new O2 sensor cannot be the prob, I was getting similar economy with the old one, the sensor is working ok because I do get better economy on long drives
In-car video showing the 34 boosting hard on full boost or its not true? Nah man but Im sure we would all love to see
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
