Yep I remember that, a mate of mine did similar - well more the doing mid 10s and 400kw on a stock motor (with just pump gas, no nitrous oxide, I must add) thing that the crowing and being banned thing :)
This car has flawless victory, however:
Yellow pages says the business still exists.
Funny to hear what happened to him in the end.. I have a few things in common with him.. A name, bit of an attitude problem and around the same time for the same reason we both... Well I wont say.
Hi, I'm Scott.
Somewhere in one of the threads around this time it came up....I can't remember which one but I am pretty sure it was alleged but can't remember if it was confirmed.
Much of what was said about making power still rings true. Power is relatively easy, longevity is harder.
totally... I think both the Simon's (R32 and S14) are good examples of high power, longevity and hard use.
My last one lasted 3 years getting pushed pretty hard at this power and that was a 200,000+ motor that had god knows what happen to it in japan (car had harness marks, camera mount marks, the turbo was clearly either returned to stock or had been popped/replaced and repair work to both rear 1/4's)
I think it is safe to say that if you get a fresh-ish 25 and it's mainly street use, (and you service/tune it appropriately / look after it) there is nothing to say you cant enjoy being in the 300 club for a long time... you just have to be prepared that there is a chance it will let go. And if it's tracked regularly, then you need to be prepared that it will most probably let go... but then again, a built motor can let go too...
I have 2 mates that have 300kw built RB's and they have been through 6 motors between them over the last 5 years... I have pushed that power out of stockers and bolt on's and I only used 2. not true of all examples, but definately food for thought if anyone is reading this and trying to make the descision
I assume the only weak point for now is the HG and if that goes I'll replace it on mine, if for some reason it's more terminal than that then I'll likely throw another stocker in its place...
The NEO is a tough bit of gear and I hope it holds up :yes:
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
