I'll have the resonator chopped to look inside i reckon, i just assumed it was big enough, whole system cost me $200 from wrecker, its 3 1/2inch jap and had jasma rated cannon but stepped down to 2.5 inside muffler, so i put an Xforce 3.5inch on the back ... But ive got a HKS muffler from an R33 which i drove and it sounded proper angry and has the restrictor inside, sound is important to me atleast if not many others...
Edited by AngryRB
  • 1 month later...
mods: gt35r .86 r/h, type a poncams, 6 boost, 50mm progate, freddy, fmic, 1000cc ev14s, link g4+
fuel: p98
power: 335rwkw
oil: ?
useage: R&R abuse
lifespan: 2 months so far
failure: N/A
comments: Soon to be e85 and hopefully close to the 400 mark.
  • Like 1
Mine is getting tuned on the 20th. She will crank 300 and unopened apart from pon cams. Will update when I have it back in my hands if she doesnt kick a leg out the bed!!
Well I didnt make the 300kw club, will go back early next year for more boost. 17psi straight off the gate and boost controller turned off got me 293.8kw.
Good work anyway!
I made 289kw so I also missed out on being part of this club
how can you not know what oil you are using lol
I can't remember what my mechanic used last time he did it. He specializes in RB engines, so I trust he put in the good stuff. 10w30 motul rings a bell though, but again, no idea.
Probably due for a service soon. Cheers for the reminder.
I hope not lol.
Have a look through the first few pages for oil reccomendations :)
Can't believe people still pay top dollar for big name brand exhausts when they are all known to have step downs and all sorts of restrictions.
Custom exhaust with your own choice of cat and mufflers every day of the week, it's a real no brainer.
cause it doesn't matter how many time people get told and shown they still choose to close their eyes and cover their ears in pure ignorance
Hmm, I would be interested to know difference in price also - custom v name brand. I know the tomei expreme is supposed to be 3.5" but It is very very very expensive for a cat back system (probably being titanium).
waaaay to thin, asking for trouble
For the power I am making, or in general?
My pressures seem to be ok. I had a look through "The goods on oils" page and it seems a lot of people are saying Nulon 10w40 is a decent oil. What would be the issue running that?
I'm doing my dump to tip in 4 inch at the moment.
$710 for two SMB mufflers at my size (the biggest I thought I could squeeze in there).
$435 for 6 m of 4 inch tube, 3 90's, 4 45 degree bends and a 3 to 4 inch expander.
Labour to do it, not sure.
Few bucks for hangers.
You only wanting a car back should be done in 4 to 5 hours with a good operator and half the amount in material.
Ive used nulon 15w50 full syn. in my 33 for years. Ive never had an issue. Plenty of street driving, and a lot of track work. Im only about to switch to Penrite 10 Tenths due to switching to E85.
I believe Nulon make a quality product. I also use their red coolant and power steering fluid. I use Redline Shockproof in my g/box and diff, but haven't looked at anything nulon offer for them yet. They'll be getting serviced before this rebuild is finished, so I might see what the have there.
I had massive issues with motul oils before that, hence the change.
Edited by R31 drift pig
  • Like 1
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
