if you dont make it then just have the tuner create a good graph and claim it to be your own, thats my plan ;)
No cheating ya goose :P And you'll be fine with your setup
I wanna join :(
Fingers crossed the SS1PU can push me into the 300's with WMI or E70
I'm only just in the club at the moment as I'm on gate pressure :(
Anyone had Err 100 on a HKS EVC before? Seems to happen every time I give it a thrashing so I've switched it off :/
Yes, yes it is. Either that or it's the tune.
There are only two factors really, but im guessing it's a foot problem.
And my figures quoted earlier - that wasn't using the O2 sensor. That was with it disabled and the tune adjusted to suit.
or sensors are broken
if the sensors are f**ked (reading lean) the ecu reverts to the base fuel map, so if that's tuned properly you shouldn't get bad economy from busted sensors. The ecu only uses the o2 sensors to trim fuel on cruise, it'll never add more fuel than the base map.
Unless the sensors are telling the ecu its running lean so it adds fuel.
I have seen it alot. Unplugging the sensors then helps with fuel economy
DVS Tuning helped me
Join this club today .
At this point in time my 34 gtt sedan is making 353kw on eflex but howevet running out of fuel
Tune soon to be 100% completed once fuel system is upgraded again.
What if the coolant temp sensor is broken and constantly tells the ECU it is cold so it runs fuel enrichment and ignition retard? Definitely make a big difference to fuel economy!
Lol 34geeteetee I'm pretty sure err 100 is an open circuit. To test that have the car running at a time the Evc is working fine then unplug the solenoid. If it gives the same error thhen that means open circuit.
it would be doing.that when its hot coz the heat makes it expand and It must have a dry or cracked solder joint inside. Make sure it is far.from.the. exhaust and that the solenoid barbs point directly skyward.
also why.does it Sig say 360kw but u keep saying its in the process and are up to 300 odd? 2nd tune?
Thanks mate... Will hopefully get it sorted before Texi...
360kw was the highest run... It was run @ 357kw on the final tune for safety... The reason for the different power figures is the 3 boost levels and also the % of ethanol.... My power ranges from 311kw to 357kw depending in boost and E content :)
Hope that makes sense?
Duno what it is mate, its pretty f*ked getting 19-20L/100kms, will definitey have that issue addressed in the tune when I do a turbo upgrade/ tune. My new O2 sensor cannot be the prob, I was getting similar economy with the old one, the sensor is working ok because I do get better economy on long drives
In-car video showing the 34 boosting hard on full boost or its not true? Nah man but Im sure we would all love to see
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
    • Highest combustion temperature is achieved at 14.7:1. (or, I should say, lambda=1, because 14.7 is not constant for all fuels). NOx increases exponentially with combustion temperature. So it is in the engine designer/s best interest to find a way to operate at lower than stoich max temperatures if they want to minimise NOx. If you want to minimise CO, you really need to run at least 14.7:1. Any extra fuel can realistically only ever report to NOx. O4 HCs if you are sufficiently sub-stoich, or if the engine's fuel-air mixing is up the shit. All of this presumes that the catalyst is not doing anything, of course. In reality, the cat is there, it is doing things, and how capable it is of eliminating either NOx or CO will depend on its age, quality, design, operating temperature, and how much the engine/ECU is designed to help it along, with fuelling strategies, air pumps, etc. And of course, RBs, even those with very capable aftermarket ECUs, usually don't have anything to help. They are just tuned to make power.
    • It's... way cheaper than what SP have on their website? I can only imagine if I say "can you make this muffler, but entirely different dimensions outside of the spec you offer as customization on your page" it would get even more pricey. I was looking at their race mufflers or their 'ultra quiet resonators' which are just smaller mufflers. They start at $166 USD which is $264. SP mufflers resonators start from $299 and are too long/not wide enough/can't be made short enough.
