Thanks mate... Will hopefully get it sorted before Texi...
360kw was the highest run... It was run @ 357kw on the final tune for safety... The reason for the different power figures is the 3 boost levels and also the % of ethanol.... My power ranges from 311kw to 357kw depending in boost and E content :)
Hope that makes sense?
High exactly does this work?
Do you manually have to look at your ethanol sensor reading and then make the call on which boost setting to run? And where are you getting the fuel? I mean if your filling at a servo I don't see you would need different tunes for E%..
Yeah mate, we only have a few servos up here with E85.... If I want to go do Putty Rd I'll burn a tank of fuel and there is no e85 within reach, so I can add pump 98... I don't know why the whole thing is confusing? Below 60% ethanol I tap the boost controller to low boost.... Not that hard :P
Although at the moment I ain't running any boost :/
Its not im just abit slow and I live in Victoria, the E85 state :)
So does the Haltech work in conjunction with the ethanol sensor to adjust the mapping automatically?
I don't get why you can't run the high boost setting on all of the tunes?
Ahhh well slow and Victoria go hand in hand :P haha just kidden.....
Mate, JEM tuned for safety, they set the tune So I could thrash it, limiter bash it and it maintain safe AFR's..... I can run 21 psi safe on E85 but on 98 18 is the safe limit.... There is ways to set it up so it changes, but of your now clued up enough to change the boost controller, you shouldn't have a powerful car lol.....
tuner setup low boost on my car and I have NFI how to change it hahaha
safety is overrated. RB25's are cheap.
Duno what it is mate, its pretty f*ked getting 19-20L/100kms, will definitey have that issue addressed in the tune when I do a turbo upgrade/ tune. My new O2 sensor cannot be the prob, I was getting similar economy with the old one, the sensor is working ok because I do get better economy on long drives
I have no idea how these guys are getting 12L/100 in my 5 years of daily driving rb20/25's I never once got better than 400ks to a tank most of the time it was 300-350, my 2.2L camry does 13l/100 at best lol
E85 in Richmond.
A bit of fun of running with glove box
Still need to change to running a Mac valve
Don't KU36s last longer than RSR though? I know RSR is a more grippy tyre but they really don't last.
yeah, but they are just not enough tyre for the current price.
when they hit the market they gained a huge popularity cos they were cheap and grip. however kuhmo saw this popularuity and raised the price a few times. now you can get a better tyre for the same or less.
FWIW NT05's last me longer than the KU36's (admittedly I have only had 1 set of the Kuhmo's)
the ones on the front of my car lasted a year of daily driving and 3 x deca's and were still going when i sold those rims (the rears lasted the same, but were basically full slicks by then)
maybe we are better drivers... :P
Have heard a few complaints about 36s glad I didn't buy them ..31s seem to be a better tyre for the money by all accounts..
Nittos just over 400$ for 255/17s pretty good value and look more like a track tyre than street..whT are they like in the wet ?
Will either get these or splurge on the yokos :thumbsup:
I imagine that would only be possible if boost was being controlled by the Haltech? With boost being controlled separately by the HKS EVC, it's not going to do it automatically.
Yeah it probably does work with the Haltech boost control, i didnt go down that path as i thought the boost control was ordinary from what i had read.....Good call on that one..... NOT! :P
As for the E sensor, i had to run it for the flex setup, its pretty good! At E65 now :D
Lol 34geeteetee I'm pretty sure err 100 is an open circuit. To test that have the car running at a time the Evc is working fine then unplug the solenoid. If it gives the same error thhen that means open circuit.
it would be doing.that when its hot coz the heat makes it expand and It must have a dry or cracked solder joint inside. Make sure it is far.from.the. exhaust and that the solenoid barbs point directly skyward.
also why.does it Sig say 360kw but u keep saying its in the process and are up to 300 odd? 2nd tune?
Hmmm from what i read the Err 001 was open circuit? The stepper motor bit is tucked in the far right hand side of the engine bay, as far away as it can be anyway...... AND i think the barbs are facing down, why would that cause a problem? REALLY hope to get it fixed as its giving me the sh!ts :/
its a gravity operated solenoid, so it wont control boost well if its upside down. it says it in the HKS book lol
so if you read err 100 was open circuit, and i said that i think its an open circuit, doesnt that mean its an open circuit? sorry man just wondering if you made a typo there lol.
if it is an open circuit refer to previous post
Gravity eh? :glare: lol well i think i better tackle that is issue number one!
Nah wasnt a typo, i was reading up on it (well trying too) and i thought Err 001 was open circuit and Err 100 was Stepper Motor Memory or something like that, it says to do a reset or something but as i know fck all about it i have been hesitant to do so, i switched it off so its on gate pressure and yesterday it still come up Err 100 after a squirt....
I am retarded when it comes to this sort of thing :ph34r:
Thats $400 per tyre?
That's rather expensive, I would rather rsr's I think
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
    • Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90°s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
    • Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 😭
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
    • Yeah its tuned relatively conservatively being dynoed at 525hp with every bolt on and top end of the motor built wtih HKS vcam and springs etc.
