R33 S1 RB25 with nice deep gouge marks in 2 bores
mods: genuine T6725G 8cm, standard intake manifold, HKS cams/cam gears, NO VCT, RB20 loom and ECU
fuel: BP98
power: 311kw on 19psi
oil: penrite 15w40
useage: drifting
lifespan: have only done 1 event in it so far but seems strong, no blow by or anything
failure: none yet
E16C0E13-7A45-4DF1-81D6-4948F531E79F-252
Hey guys, can I join?
mods: 3" exhaust, greddy 600*300*76 intercooler, nismo fuel pump, nismo 740cc injectors, Hypergear ATR43 G3 turbo, low mount, stock manifold
fuel: e85 Caltex EFlex
power: 304 @ 17psi (clutch slipping so can't go further)
oil: Castrol Edge 10w60
useage: Daily driver - to and from work - occasional mountains flogging or track day
lifespan: Owned for 3 years still going
failure: None - touch wood
comments: So much fun!
Hi Tranman , I'd like to see your intake from the Z32 to the GTX3076R if possible because many claim its difficult to do .
Do we know for sure if the std GTS25T airbox can't support 300 RWKW , I still have mine and it has a cleanable Piper Cross element in it . I'd also like to see the box mods as I like stealth and I'm using the same IC as yours . The airbox in R33 GTRs must be significantly better if it supports more than 290-300 RWKW .
Good effort , cheers A .
Pictures (below) of what the workshop (Chasers Motorworks) did to open it up the stock airbox. They also fabricated the intake pipe to the turbo using a silicon hose joiner from the z32 to the 3" metal intake pipe before joining to the turbo via 3" to 4" silicon hose fitting. I was advised it was a bitch to do by the workshop.
The stock airbox was holding me back on my car hence needing to drill out holes. Not saying it will/may hold others back if they have better flowing setups etc.
Was tough getting a pic to show you the pipe from the z32 at this time, but you may be able to just make out how it reaches the turbo.
I looked up pics of the R33 GTRs airbox and it seems to lay on its side so there is a greater volume of air either side of the element .
Has anyone tried to use the 33 GTRs box in a 25T ? Probably a bit of stuffing around making a Y pipe but if you're doing something for a bigger turbo inlet ?
A .
Edited by discopotato03
i wouldn't worry about water... I ran my car like that for 5 years with no issues.
(not the hole cut in the stock airbox, but a pod in a custom box with a CAI from the front bar
