It's almost the same power as mine made on Jez's dyno with 98ron so it must be there or thereabouts. Comparing it to a different dyno in a different state might be bit hit and miss.
i think he is referring to mine on e85 that was a good 40kw higher... so more a blanket statement about fuels and the turbo's capability
that HTA result is nothing short of amazing!
makes me wish i still had my car so I could do a run on the same or similar boost and see the difference.
but I chickened out on 20psi :/
I'm sure Lithium would agree that the GT3073HTA would also be interesting to see wound up on an RB25 . I don't know if FP would ever consider doing a GT3071HTA but that could also have potential . I don't suppose anyone knows which compressor housings they use with the 71 and 73mm HTA wheels ? I think they use T04S 0.70 AR ones on GT3076HTA turbos .
Thinking about it they have a 68mmHTA compressor and I wonder if it could beat the GTX3067R for a razor sharp 300 WKW capable turbo .
A .
FP do a HTA3071 (51lb/min) as well as the HTA3073 you are aware of, there are a few HTA2868s lurking around too. I most definitely do not overlook the HTA3073 at all, I had actually toiled over recommending that unit to 34GeeTeeTee when we first got to discussing upgrades for him which would give him improved response and no loss of power, but it became clear that he'd get a kick out of the extra headroom to go up to the 380-390rwkw (yep - we specifically discussed that power area prior to the tune).
The HTA3071 has a 51.2mm inducer, 71mm exducer so is a smaller compressor wheel than the GT3071R - again like the HTA3076 vs the GT3076R, so you would be looking at something that would make power somewhere between the GT3071R and GT3076R but be stupidly responsive.
After talking to 34GeeTeeTee about his driving impressions the dyno plot doesn't do it any justice (which to be fair I always knew would be the case, but still).... it sounds nuts, I am sure he will make a post at some point on the matter. If what he has said to me so far is anything to go by, then the HTA3071 would be porn for the likes of DiscoPotato and yourself.
I was just looking at an American board and I think they quoted the 71HTA wheel as having same inducer and exducer sizes as the GTX71mm compressor only 7 blades rather than 11 . I think they also quoted these wheels as both having 51 pounds air flow capacity .
A .
They are wrong, the GTX is 54.1mm inducer which is almost the same as the HTA3076 (54.8). The HTA3076 would probably make the GTX3071R feel lazy, the HTA3071 would be something else methinks.
Sent from my GT-I9505 using Tapatalk 2
Hey guys,
just bought an r33 gts-25t.
makes 330rwkw @ 20psi and was tuned by Unigroup with a Power Fc
Has an unopened rb25det with:
Garrett Gt3582r 0.82
Generic Stainless Highmount
Turbosmart 45mm Gate
3.5" Kakimoto Mega N1 Exhaust w/ no cat
Siemens 750cc injectors & custom fuel rail
Turbosmart FPR
Warlbo 255 internal and Bosch 044 External Fuel pump + Surge Tank
Power FC
Freddy Plenum
Ace Intercooler
Planning to downsize to a Gt3076r 0.82, swap to a low mount steampipe manifold, fit a quieter exhaust + high flow cat.
Hoping to stay around the 280-300rwkw mark.
just food for thought... if it's a street car you would get away with a stock manifold quite easily with that turbo. only time you will see a REAL benefit is if you run e85 and are pushing 350rwkw however then you are also probably going to need slightly bigger injectors.
also look into the FP 3071 for that power
(so we can see some results :P)
Hahaha good old FP :D
Welcome to the club Bennis, when you get the car bring it around so i can have a look :yes:
Hey guys, We have started a dedicated HTA chat so for all info etc please post up in the new thread here -
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
  • 3 months later...
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
