Unfortunately my headgasket started leaking about 3-4months ago, was making 302-308 rwkwk on 19lb on 98. Fixed it in a couple of weekends, Put new nissan headgasket and head bolts. Aiming for 340rwkw and up on e85 :) Anyways here's how it looked when i cracked open the head!
With that cylinder pressure I would be swapping out the factory head bolts for some ARP 625+. Your call at the end of the day... Perhaps you enjoy changing head gaskets. :P
Doing jobs like that is my occupation. If she shits a gasket ill put a mls gasket and uprated head bolts or arp studs
Edited by LTHLRB
  • Like 1
Are you another Kiwi? We only have E85 at two pumps in NZ that I am aware of. There are guys who bring in Sucrogen E85 (works out as like $3 a litre) and we've used this on flex fuel cars: http://www.trademe.co.nz/home-living/cleaning-bins/other/auction-634702052.htm
I've got a spare motor, things never break when you've got a spare :D
E85 is still hard work in NZ
Looks like i gotta put a spare short motor aside and wind the boost up. Test your theory
Yeah, still only the two pumps. Taupiri Auto Store have drums of Gull E85 which works out around $3 a litre too, may end up having to go that way
  • 1 month later...
Standard unopened RB25DET Neo 150xxx K's
Hypergear ATR43SS2 internal gate
Standard exhaust manifold
Standard intake manifold
RB25 S2 throttle body (deleted traction control and cruise control)
3"JJR Mild steel bell mouth dump pipe
3" straight through exhaust (no cat)
R32 GTR intercooler
Xspurt 1000cc injectors
Standard fuel rail with 4mm spacer
Greddy Profec B spec II
R34 NISTune ECU
Pic to come soon.
R32 GTR intercooler
R34 NISTune ECU
Pic to come soon.
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
