My engine is still going strong! 11000kms on over 350kw now :D
man those R34 NEO motors are built like german nazi tanks lol
it seems like it's more economical to drop in a R34 NEO motor if a R33 RB25DET motor ever carks it
They tend to hold together pretty well! Ill admit mine has had a hard life too! Its been overheated (Well got warm but Haltech shut it down) and also had a LOT of fuel dramas which caused all sorts of bad AFRs early days... I try to keep it off the limiter but it still gets spun to just over 8000rpm when up it haha
Sick effort. Mines close to getting on the rollers. Patience is running thin though
It gets like that! Itll all be worth it on that first drive though ;)
Funny thing is I'm the one doing all the work. Just a matter of putting in the effort after working all day on shitbox cars (skoda). Sometimes all you wana do is sit on the couch and not move lol. Will be tuned within the month though
I would like to be able to say the same. But i give mine a fairly hard time. Seen 2 track days and lots of limiter, although mine is set at 7450 from memory not 8000 haha.
Even driving it very hard, no blowby AT ALL! or any oil/fluid leaks, just running the standard nissan setup. ie linked rocker covers and then a hose to the intake after the AFM.
The thing i am most impressed with is its off boost driveability though, it is insane! Put your foot down in any gear and it just accelerates, even crusing at 100 in 5th, half throttle and it just accelerates to 120 easily all while off boost!
I am certainly very impressed with the NEO!
Unfortunately mines dropped cylinder 5 :( flaming mongrel!! Im not sure what caused it, had plenty of vacuum leak drama from the plenum in past year and an accidental overboost of 25psi in third, all cylinders 155-160 and number 5 is 60..goes upto 200 with some oil squirted in.
rebore and forgies n rings or drop a stocky? thoughts?
Edited by AngryRB
I thoughtyou sold your 33? You building another or same but different way? Id throw pistons and rods at it but all depends on your power goal and what you wish to do with it.
that was the plan, but then discovered the dropped cylinder and now thinking ill just have another crack at it, will be a 300kw and ethanol , keep it very simple this time with a 0.63internal rear
Edited by AngryRB
forgies...and 500kws...:P
Yes and no, depends on your powergoal. You've got Matty spinning up 390kW on a dead stock motor and it also gets punished. I've sbeen how he drives it lol
So why spend thousands when a drop in NEO will cost you half the price of a basic engine rebuild?
Just my thought.
I have 2 mates that had 300rwkw 25's for the same time I did, one drivin like mine, the other PUNISHED. both of theirs were built motors from very well reputed workshops, and both of them are on their 3rd motor now. while mine was on it's second when I sold it
with these power figures its a lottery either way, so i'd just got another stocker personally.
car is dedicated E85, its a big decision, having thoughts of running a higher comp ratio of mid to high 9s, gt3076 with .63 rear internal, goal is driving on streets and drags with reducing lag and making it feel very punchy on the street. 300-320kw max
stocker- solid from factory but still old and 155av comps..
rebuild- new pistons/rings ( possibly forged) and have 180-200 comp = more grunt and earlier boost for the streets
much simpler to just drop stocker in though and maybe shave a bit off head, don't want to overcomplicate stuff
Edited by AngryRB
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
