But in saying that backyard builds vs workshop builds. There is only one way to put together a bottom end. The correct way. Regardless if its a glamorous workshop with tip top race cars or somebody in a shed such as d'anallo performance who has a rb25 30 running into the 8s. Quality workmanship is quality workmanship.
My theory on a workshop is. If you're going to open a workshop you should know how to build an engine properly as a minimum. You learn how to do that in your 4th year of trade school. Iv had bad experiences with a certain shop that did an abortion of a job on my car. I basically redid all their work to how I wanted it and its yet to fail me (still using a stock bottom end). And all that work was done off a hoist in a small garage.
I do agree with you on experience. Trial and error plays a big part when pushing the limits.
I still don't understand why "professionals" can't do the job that they're payed for correctly. We as customers pay the 100% price yet we dont get 100% effort or quality. Same goes with "tuners" what irritates me is some workshops won't put as much effort or care in a tune if you built it elsewhere and braught it for a tune yet they will go to the moon and back when you have them build you an overpriced engine. Work should be done 100% regardless of where the car came from.
Won't name any famous tuning shops, but I've seen for myself copy and paste tunes across similar cars.... and funny how "they were all tuned from scratch" ra ra ra.. and tuned the cold start, etc... car probably saw about 15 minutes of dyno time and copy and paste of a bin file... $1100 later, see you bye.
Spend less time dealing with workshop lies and empty promises and more time tearing it up.
On another note. If the stock quality is so awesome why are so many rb 26s failing due to oil starvation? Or any engine for that matter? Not saying its poor quality. But saying a built engine with all the trimmings is/can be a lot better.
A lot of this is attributed to people putting sticky tyres on them, doing a number of hotlaps and pulling massive lateral g's
So modifications would need to be made to suit the application. Like baffled sumps and what not. Always room for improvement. If those mods were made prior to raping the car on the track would the stock internals last? Edited by LTHLRB
far better chance i'd say
nissan didn't design the car to be exiting corners at well over 100 kph with R comps on all 4 paws after 10 hotlaps
the oil pickup isn't even in the centre of the sump lol
1998 r34 gtt 4 door sedan fact manul.
Rb25det neo
Pon b cams
Pfc
Walbro 416 LPH pump
E85
Gtx 3076r . 82 machined out int gate
Uprated actuator
Split fire coils
4" dump into twin front pipes(120mm) in hks super silent exhaust with hi flow cat
Standard clutch
Made 325rwkw 20psi wheel spinning due to using 10" wide super sticky dun lops on 40 psi, dropped to 20 psi but were still way to hot.
Next is upgrade clutch and change rears then up boost
Rb25
Etm manifold gt3582 with t04z wheel and highflowed 4inch exhaust
Microtech lt16
Spitfire coils
Forward facing plenum
850cc injectors 2x 044
Process west 96mm thick cooler
Jim berry full Monty clutch
Eboost 2
Didn't make the dyno only street tuned and cracked ring lan and ripped engine mount apart
Edited by paul_psi
could you tell something was broken and what had caused it, eg boost/revs or both? im bit confused when mine happened cause even on 5 good cylinders it was pulling hard still, just idling rough.
Edited by AngryRB
so is forged pistons the only answer to breaking ring lands? planning rb30det ( 9.5:1 and 3076) and want to be confident I wont break another ring land. I don't like piston slap so forgies not ideal for a street car..
Edited by AngryRB
Keeping the cylinder pressure low and knock under control would help with extending the stock piston's life. Even ethanol can't remove detonation, especially as the temps start to rise.
Piston slap shouldn't happen if you choose the right piston materials, as long as the bore is machined correctly.
Hey guys.
Im making 425 at the rears in my GTX3582R setup.
Neo cams kinda look gay on paper, is it worth upgrading them for when I go e85? I'm looking to make 500 on a stock motor and head gasket.
Hey guys.
As in the duration? cos the lift is higher. Remember that they are solid lifters so can run a more aggressive ramp rate for a better overall result, so not as bad as they seem. Edited by superben
Depends on the cause, if you have knock then you'll still break them they just might take 6 months instead of 3 months to snap. If you are breaking them due to genuine high cylinder pressures eg 3-400kw then they will help, though broken ring lands in these motors are almost always due to knock, you might have an issue that doesn't show up during dyno time that is causing the problem.
Piston slap with forgies is only due to big clearances, it is a tight call between slap and the piston siezing, just make sure the expansion coefficients of the pistons aren't too excessive and then you can run tighter tolerances, maybe give RIPS or race-pace a call and see what they recommend piston wise (and clearance) for minimal slap.
Hey guys.
It's probably worth the upgrade if it's a number you are chasing as the only other options are even bigger turbo's or more boost
depends on which cams really
I just didn't want to go E85 and not make the most of it by not having the suipporting mods.
I'd rather have something that comes onto boost harder in the mid range than chase a specific peak number,
  • 2 months later...
Stock RB25DET (head bolts, head gasket, internals)
hks 256/264 cams and ex cam gear
nismo 740cc injectors
apexi pfc with a z32
garrett gt3076 .82 turbo with tial 44mm gate
GTR intercooler
Greddy plenum
Tomei 500hp lift pump with a 044 feed
Nismo fuel reg
23psi and BP Ultimate
BIG thanks to Trent and Cat from Chequered Tuning. Glad to see there are still legit people in the Auto industry.
Edited by LTHLRB
  • Like 1
R33 Rb25det Stock engine
Brae exhaust manifold
HPVA 50mm external gate
HyperGear SLSS2 Turbocharger
600x300x75mm Intercooler kit
3inches turbo back exhaust
1000CC injectors
Power FC
E85 Fuel
Final result of 356rwkws @ 20psi
    • Definitely needs ceramic coat and fresh wax every week. And cats. Running with no cats is a (unt act.
    • Welcome. Dont let anyone dissuade you from your dreams. If you want a gtr, keep sabing and you will eventually get one. I feel like if I had have bought stocks, those companies would have gone bust and I would have lost my money.  There's a gamble in everything we buy. I've had good times and bad. But... I've also met my absolute best friend through this network and can't imagine life without them(more like a brother). Keep in mind, some specific mods will change as technology gets better. If you feel like general chat, there's always the wasteland.....
    • Those are some very cutesy barriers! Is that common?
    • Saw this abandoned Honda Fit in a carpark that was getting repaved... they just 'cut around it' and continued with the job! There's a number of reasons why the car could have been abandoned, but as for the construction company, legally they don't have permission to move the car from the owner (who has moved on and can't be contacted) so all they can do it just leave it there with enough space around it so it won't get damaged.
    • You’ll want to have the block drilled and tapped to suit 1/2in head studs and the head for the same. How much power do you intend to make?
