300Kw Unopened 25 Club...
what did you do to them excatly? id love some pics hahaha the setup looks the same as a r33 one thats why were baffled at the problem
Drilled the plastic factory 90 out and replaced with a speedflow fitting... Have pics but no idea where, found it for another 34 owner the other day but i think it was on FB
Not 300 but mine takes an absolute flogging daily with 260kw, no signs of wear to date, been about 5 years now. Lil old rb20 gearbox has been replaced a few times though! :lol:
I have had no issues maxing an e85 Walbro without drilling or modifying the fuel tank at all.
Well that is a good sign... But i doubt the filter is a restriction as i run the paper type and have no issues!
Hey guys,
This is a neat little club going on here and I've decided I would like to join it!
Need a little advise before I get there though. Obviously number 1 issue for most people is money, so I have 15K to achieve my 300kw dream (including price of car)
I've found an r32 with S1 Rb25 conversion with following mods already on it
Engine:
HKS EVC 3
Nistune ECU
Front Mount I/C with hard piping kit
3" Turbo back exhaust, high flow cat
Walbro 255lph in tank fuel pump
Gearbox:
RB25DET Gearbox
Exedy Heavy Duty Clutch
Custom Tailshaft to suit new gearbox
Standard Differential
Suspension / Handling:
BC BR Coilovers
Cusco Fixed Upper Camber Arms -3 deg
Hardrace adjustable Rear camber arms
Hardrace adjustable Rear traction rods
Rear Adjustable toe arms with Lock bar
Front R34 GTR disk brake upgrade
Price of car is gonna set me back (9-10K based on negotiations and is also the reason for this exercise to see if buying the car is worth it for my goals)
Based on what the car has I think it covers all the odds and ends that aren't directly related to power but is needed anyway, so the rest of my budget can go on go fast bits
With 5/6K left my shopping list to get me to 300kw is:
GT3076r low mount kit - $3200 (could go GTX instead for $200 more...undecided)
Xspurt 1000cc injectors - $775 (same price as 750's, figure why not)
Z32 AFM - $150 - $200
Turbo Smart FPR 800 - $270
Tuning = $1000 (guessing)
Total = $5500
I don't think any of that is over complicated to install myself but have obviously budgeted for professional tuning.
Now...is there any holes in my plan, anything that will have my hopes and dreams come crashing down on me? I have read a good chunk of this thread and based on other results I don't think I would be far off.
I have not purchased or made a final decision on this particular car, so if this combo will not work I will explore other options, so suggestions are welcome
I have been through the rb25 turbo thread and this one so I know there is plenty of info out there, i'm not trying to get someone to do the work for me, but it would be nice to get an outside opinion on my plans to either set my mind a bit more at ease or prevent me from making a mistake.
Thanks!
I wouldn't know... I fell short of the 400 mark by 9 little bastard wasps :P
Why the stainless fuel filter? I run paper filters and they are not a restriction is setup correctly?
Closer than me, sprung an oil leak last dyno day, stopped at 365 due to starting to make too much of a mess :whistling:
Might have to go again, still on 98e10 but should be able to wind some more out of it :D
Edited by WMDC35
Perhaps the brand or part number was different, but both times I have seen it on 34's the filter was an issue. Probably just blocked with gunk, but they were changed recently...
At least the tank setup is good for 430 or more kw in the 33 and 34.
I have seen a couple max out, base pressure and boost pressure were pretty close though I think. 40 psi base with 30 psi boost. You could get a bit more out of them by dropping the base pressure a little.
You should see at least 400kw, these maxed at 430 and 450.
Thanks!
Just buy a car with 300rwkw already, if you do buy this car buy a $900 highflow instead, will save you getting defected (you will), and when you are $2k short due to a bunch of things breaking that you didn't expect you will be able to afford them. Just stuff like tyres, random broken stuff, trust me you will get caught out.
Even 250 will be useless without expensive tyres and a diff, you need a replacement diff centre or you will be peeling it out everywhere and put it into a tree when it occasionally does twin up, same with tyres.
Wise words.
Remember 300rwkw is useless without good Diff/clutch/tyres
300rwkw can be quite a handful if the car isn't set up properly.
Trouble is that everyone can have 300 pretty easily on a relatively stock car
Or buy an awd base to begin with if you want traction. ;)
:yes: Once i got my suspension and diff all sorted the car was a lot more fun to drive! And a lot quicker too!
FYP. :P
:laugh:
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
