I'll have the resonator chopped to look inside i reckon, i just assumed it was big enough, whole system cost me $200 from wrecker, its 3 1/2inch jap and had jasma rated cannon but stepped down to 2.5 inside muffler, so i put an Xforce 3.5inch on the back ... But ive got a HKS muffler from an R33 which i drove and it sounded proper angry and has the restrictor inside, sound is important to me atleast if not many others...
Edited by AngryRB
  • 1 month later...
mods: gt35r .86 r/h, type a poncams, 6 boost, 50mm progate, freddy, fmic, 1000cc ev14s, link g4+
fuel: p98
power: 335rwkw
oil: ?
useage: R&R abuse
lifespan: 2 months so far
failure: N/A
comments: Soon to be e85 and hopefully close to the 400 mark.
  • Like 1
Mine is getting tuned on the 20th. She will crank 300 and unopened apart from pon cams. Will update when I have it back in my hands if she doesnt kick a leg out the bed!!
Well I didnt make the 300kw club, will go back early next year for more boost. 17psi straight off the gate and boost controller turned off got me 293.8kw.
Good work anyway!
I made 289kw so I also missed out on being part of this club
how can you not know what oil you are using lol
I can't remember what my mechanic used last time he did it. He specializes in RB engines, so I trust he put in the good stuff. 10w30 motul rings a bell though, but again, no idea.
Probably due for a service soon. Cheers for the reminder.
I hope not lol.
Have a look through the first few pages for oil reccomendations :)
Can't believe people still pay top dollar for big name brand exhausts when they are all known to have step downs and all sorts of restrictions.
Custom exhaust with your own choice of cat and mufflers every day of the week, it's a real no brainer.
cause it doesn't matter how many time people get told and shown they still choose to close their eyes and cover their ears in pure ignorance
Hmm, I would be interested to know difference in price also - custom v name brand. I know the tomei expreme is supposed to be 3.5" but It is very very very expensive for a cat back system (probably being titanium).
waaaay to thin, asking for trouble
For the power I am making, or in general?
My pressures seem to be ok. I had a look through "The goods on oils" page and it seems a lot of people are saying Nulon 10w40 is a decent oil. What would be the issue running that?
I'm doing my dump to tip in 4 inch at the moment.
$710 for two SMB mufflers at my size (the biggest I thought I could squeeze in there).
$435 for 6 m of 4 inch tube, 3 90's, 4 45 degree bends and a 3 to 4 inch expander.
Labour to do it, not sure.
Few bucks for hangers.
You only wanting a car back should be done in 4 to 5 hours with a good operator and half the amount in material.
Ive used nulon 15w50 full syn. in my 33 for years. Ive never had an issue. Plenty of street driving, and a lot of track work. Im only about to switch to Penrite 10 Tenths due to switching to E85.
I believe Nulon make a quality product. I also use their red coolant and power steering fluid. I use Redline Shockproof in my g/box and diff, but haven't looked at anything nulon offer for them yet. They'll be getting serviced before this rebuild is finished, so I might see what the have there.
I had massive issues with motul oils before that, hence the change.
Edited by R31 drift pig
  • Like 1
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
