And this is probably close to as responsive as possible for the power made on a R34 GTT factory RB25det Neo, running newly developed ATR43SAT BB internally gated bolton turbo on P98 fuel. 317rwkws @21psi, 20psi @ 3550RPM.
  • 2 months later...
Why do most of the dyno grahs show power fall over at the top end?
Because most people run along the edge of the compressor efficiency curve. This means they get max turbo airflow in the midrange and also in the top end. If you get similar airflow at 5000rpm as you do at 8000rpm then this means reduced torque as you are sharing the same air over more combustion events, reduced torque means reduced power.
Most factory turbo cars don't smash the boost in the midrange or max the turbo out, hence they can hold flat torque to redline. If they didn't then you'd see the typical huge midrange torque and dropping off at redline.
Tao, what is the expected results on an RB25DET? Considering swapping my turbo out for a smaller one for less lag.
If I drop the exhaust or run external gate, top end torque curve would be more flat. For a good turbo configuration on a good internally gated setup. On pump fuel, The torque curve is usually an umbralla shape.
ill be running the non bb version of the 43sat iwg on my car, hoping to tune it next weekend yet that will depend if a part i ordered tonight gets here in time, if it doesnt then whatever day it gets here ill throw it on my dyno and see how it goes. stock rb25, 3"tbe, fmic, so that should give you a better idea if you can wait a week or two
  • Like 1
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
