Mods: S1 RB25DET, kinugawa td06-20g internally gated and rear housing ported and ceramic coated, ceramic coated factory exhaust manifold, 3" turbo back exhaust, FMIC, cai, nismo 740cc injectors, walbro 460 with fuel pump mod, nismo fuel reg, turbosmart boost tee, power fc, splitfires
Fuel: caltex e85
Power: 304rwkw on 18psi
Oil: penrite 10 tenths 10w40
Usage: daily
Lifespan: had the car for 8 years now but its only been 6 months since running with 300kw. No issues at all so far [emoji5]
Failure: nil
On 11/30/2017 at 1:25 PM, Stick180 said:
Finally made the club. Completely stock 25 Neo including all manifolds.
mods: Borg Warner Airwerks S257SX-E TS 0.83 on stock manifold, Tial MV-R EWG, Bosch 1250cc injectors, Walbro 485 with hardwire mod, 3" turbo back exhaust with highflow cat and HKS Super Drager muff. HDI IC, 3" intake, Nistune with feature pack 2 and flex fuel sensor. Bosch R8 coilpacks
fuel: BP 98/ United e85
power:266rwkw 98 + 18psi/302rwkw e85 + 19psi
oil:Penrite Racing 10/Tenths 10w40
useage: Weekend warrior/ some track days
lifespan: 172000 + 1 week
failure:
comments: EWG needs more spring (0.3 bar) so has some lazy spool (140kw @ 4000rpm) and drops 2.5psi from 5500 to 6800 rpm, so gate is blowing open.
Should update this, went back for some fine tuning to the e85 tune, and turned boost upto 23psi. Made an extra 30 rwkw.
  • Like 1
Is the boost control issue sorted?  Still looks a little on the lazier size
Yeah, its holding boost to redline now. Yep still lazy, probably lazier now after the retune, but i guess thats the joys of journal bearing turbos. Not unpleasant to drive though. Still chasing an electrical issue (TPS or TPS voltage, something to do with Nistune, dunno) where the car goes into a limp mode of some description if it bounces the limiter so haven't been able to do a proper run down the 1/4 yet (only managed a 13.5 @ 112mph, 2.8 60ft)
1 hour ago, Dose Pipe Sutututu said:
Need to set the rev limit counter value to 255 and also set the map sensor counter to 255 to stop it going into limp mode :)
I will give this a go.. Thank you good sir
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
