Flat Spots At Certian Rpm In Manual Mode On Auto + Alot Of Black Smoke/ruff Idle On Start Up
Hi GUys,
Its probably a ditry AFM or plugs or o2 sensor, but best for you professionals to determine :)
Past couple of weeks noticing random flat spots through the rev range, still have power, just rpm sits for abit before climbing again.
Just started the car, drove it this morning with no worries, very ruff idle, black smoke starts belowing out. stopped the car and started again, perfectly fine, no ruff idle, no smoke. No mechanical noises can be heard ie knocks etc
any ideas?
Get some new copper plugs (you don't say what kind of Stagea you have) and give the coils a good clean and examination while you're at it. If its a C34 get a new O2 sensor from Kudos
http://www.kudosmotorsports.com/catalog/ngkntk-sensor-lambda-oxygen-nissan-rb20det-rb25det-p-42.html
I recently noticed that my fuel economy is not as good as it used to be. This was starting to hurt on 98.
Firstly I cleaned/re-oiled the aftermarket k&n air filter (yes it was filthy) and cleaned the air flow meter with mass air flow sensor cleaner.
I have today received a set of spark plugs for the M35 - there is a bit already written on this topic and I chose the NGK Iridium IX (LFR6AIX-11) from PerformanceLub.
Just to cover everything I picked-up today an o2 sensor from Nissan. For the M35 this is 22690-AQ800 at around $160 incl GST. Not cheap but neither is fuel...
Sometime next week I will get around to fitting the spark plugs and o2 sensor. I will also try and get the injectors cleaned off-car.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
