Flat Spots At Certian Rpm In Manual Mode On Auto + Alot Of Black Smoke/ruff Idle On Start Up
Hi GUys,
Its probably a ditry AFM or plugs or o2 sensor, but best for you professionals to determine :)
Past couple of weeks noticing random flat spots through the rev range, still have power, just rpm sits for abit before climbing again.
Just started the car, drove it this morning with no worries, very ruff idle, black smoke starts belowing out. stopped the car and started again, perfectly fine, no ruff idle, no smoke. No mechanical noises can be heard ie knocks etc
any ideas?
Get some new copper plugs (you don't say what kind of Stagea you have) and give the coils a good clean and examination while you're at it. If its a C34 get a new O2 sensor from Kudos
http://www.kudosmotorsports.com/catalog/ngkntk-sensor-lambda-oxygen-nissan-rb20det-rb25det-p-42.html
I recently noticed that my fuel economy is not as good as it used to be. This was starting to hurt on 98.
Firstly I cleaned/re-oiled the aftermarket k&n air filter (yes it was filthy) and cleaned the air flow meter with mass air flow sensor cleaner.
I have today received a set of spark plugs for the M35 - there is a bit already written on this topic and I chose the NGK Iridium IX (LFR6AIX-11) from PerformanceLub.
Just to cover everything I picked-up today an o2 sensor from Nissan. For the M35 this is 22690-AQ800 at around $160 incl GST. Not cheap but neither is fuel...
Sometime next week I will get around to fitting the spark plugs and o2 sensor. I will also try and get the injectors cleaned off-car.
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
