For sale is my Jim Berry Fully Monty Race Clutch setup out of my VL Turbo which was running an R33 Turbo Gearbox.
The clutch disc is a carbonic 5 puk sprung centre and has a 4400 clamp load.
Also includes pressure plate, flywheel, engine backing plate and every bolt you'll need to install the package.
I'm after $1,000 for the complete setup. All parts were in excellent working order when removed from the vehicle.
Give me a buzz or send me an SMS on 0422 081 438 if you're interested. Cheers, Phil.
Picture 1
Picture 2
Picture 3
*sigh* I guess there's nothing I can do when I brought that upon myself.
Price dropped to $800 cash and I'm throwing in the starter motor to suit the setup.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
