The stillen long tube intake will add at least 15kw at the wheels and is meant to be the best intake for the Skyline v36. This plus exhaust should give you close to 30 extra kw's.
Currently on special at stillen for $525 + shipping which is $200+
http://www.stillen.c...model=G37%202DR
Brand new, unused as decided to sell my car.Great opportunity to get it locally for less & without waiting.
$630 firm
Located in melb.
Edited by pauls
  • Replies 42
hey,
This was purchased for the v36 coupe.
Not sure if these is any difference as stillen page mentions both coupe & sedan in the product details.
Don't know if there would be any difference in sedan & coupe front internals either.
I just had stillen USA check for me & they have confirmed 100% that the coupe & sedan intake kits are identical.
I can confirm slight differences in sedan & coupe piping.
Trying to find out & will provide further info.
$630 firm
Located in melb.
Hey buddy I'm interested but I'm in Sydney can you find out how much shipping will cost I've placed an order for injen cold air but haven't paid yet 525 shipped if you can do same price or better we may have a deal
Hey,
I should be able to include shipping, however price is firm.Stillen R&D plus HP improvement makes This is the best intake you can get.
1329289173[/url]' post='6236306']
Hey,
Ok is it the one that has one filter sitting in front of grill or two filters
Two pods sitting next to each other behind the grill.
Each intake has its own filter.
Also has plastic brace, protector to stop any water getting on ram pods
Buddy its cheaper for me to buy on line if you really want to get rid of them make me a good deal and ill buy them check out the price online delivered to au
Unless they are the Gen 2 or Gen 3 there pretty cheap online Gen 2 $500 delivered Gen 3 525 so 630 is very high for the first one made Gen 2and 3 have improvements on power and all else get back to me soon if you are willing to make a good price no one will buy at 630no offence thanks
Read the subject title dude. Gen3. Purchased a few months ago & priced cheaper than what you can get it delivered from USA.You may wish to do your research & read the thread next time before commenting.
$525 gen 3 in America PLUS shipping which last I checked was around $299.
Edited by pauls
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
