hi jag,
try this thread http://www.skylinesaustralia.com/forums/sh...ead.php?t=37720
I remember him having a few.... EVC 3 & 4. If it's for the GTR either a 3 or 4 will do. They both use the same stepper motor, and I'm sure have the same functions. I think he was selling these for $250 for the EVC3, and $250 for the EVC4... WOW they were cheap.
Good Luck
https://www.sau.com.au/forums/topic/38949-hks-evc4/#findComment-793036
Thanks Simon, already got in contact with this guy and he said that he was going to find out whether he had any evc4's left, still awaiting for his reply....
Your car is coming up very well down at Ice, mine is the silver one beside yours getting virtually the same upgrades..... The cars look virtually similar with the xenons, no. plates, mods....
https://www.sau.com.au/forums/topic/38949-hks-evc4/#findComment-793150
I've got an EVC 4 going in mine as you've probably already seen. On the advice of Ben & ICE, it seems alot of people are going the HKS way now. Hopefully my car should be ready today... it's been there since MAS :cheers: Either way, I have faith in the boys there, so far they have been very striaght, upfront & genuinely honest about my concerns.
PS: Hope you haven't pinched my no plates... I'll probably head down there tonight, as i'm starting to have withdrawal symptoms.
https://www.sau.com.au/forums/topic/38949-hks-evc4/#findComment-793270
Well Ive been talking to the same blokes as you have and they swear by the evc4...
Yeah they better hurry up and finish yours so they can finish mine, apparently yours is priority at the moment.....
Will have to go for a cruise one day and compare both setups.....
https://www.sau.com.au/forums/topic/38949-hks-evc4/#findComment-794234
JAG: A comparison would be good.
DAVE: I learnt the hard way, that the HKS Model description is a little confusing. So here goes...
What I got is known as the HKS EVC 4 in the US, however in japan it's know as a HKS EVC 3. What's known in the US as a EVC 3 is known as a EVC 2 in Japan ... get the drift. The model your referring to for around $900 is known in Japan as a EVC 4 with the the seperat display unit similar to the blitz model. In the US it is known as a EVC 5... Other words US seem to add a 1 infront, the same way they do with their "vehicle model years" eg: WRX 04 as we know it, is to them know as a an WRX 05. Typical yanks!
https://www.sau.com.au/forums/topic/38949-hks-evc4/#findComment-794285
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
