Not a bad job, at least the angle promotes good flow, but damn its tiny. I would have gone for a much larger gate.
What is it with everyone running 38mm/40mm gates, no love for the 50's and 60's? There is power to be made there...
Here is an exhaust I worked on recently, Not an easy job but it got the results. 0.82 split GT3076. Aircon lines remain intact.
That looks so nice Scotty. Was it expensive? Looks like there would be a fair bit of work in it.
Is there much performance loss with running a single gate off a split pulse manifold with a twin scroll turbo?
Obviously it won't be as good as a twin gate setup, but do you loose much response, power or torque anywhere?
Not really, it cost him around 2 grand for the full system, plus he had intake and cooler piping made.
I would think if you can get the gate to seal the two halves a single wastegate would work just as well, as long as it was big enough and had good flow.
It is funny how people scoff as using a single wastegate on a twin scroll manifold and turbine housing without fully understanding what difference it would make. Who ever started the rumours that you needed two "or else" must be laughing and selling a lot of wastegates!
Anyway, dividing the wastegate flows right up until the wastegate (such as the photo in the link) would be much better than just merging the two flows before the gate (like on a Greddy or HKS manifold).
Yes it is in a great spot before the turn on the turbine housing to control boost very well.
6boost do a split pulse single gate manifold don't they? Has anyone tried one out?
If you are going to the trouble of buying a twin scroll turbo, I would have thought you would get a decent manifold to get the most from it rather than putting the gate off the turbine housing? I was always under the impression people only did the gate off the turbine when wanting to run external gate on the stock manifold
Edited by Mitcho_7
As the highest pressure point it makes sense to me to run the gate off the housing which is why I talked Artz into it. The idea for my setup, (if I ever get around to making it) is to get the flow straight through the turbo, cutting out the back of the scroll and making the wastegate the priority when it is open. With twin scroll just run the splitter up to the gate and the same will apply.
Too many setups I see favour the turbo at the expense of the wastegate flow which would mean too much power is lost up top imo.
The whole point of twin scroll is to work in the firing order 'pulse'.
Would make sense...
Manifold is divided
Turbine housing is divided
... that the wastegate would follow a similar premise.
Be good to see some actual information/testing/data with single vs dual with a true T/S setup to dispel - I'm assuming you have some?
I am assuming you do thinking it is undoubtably better.
You can't have evidence for everything (I see you honking that horn a lot be-littling people) sometimes it is just not feasible. You should understand that there is more "best practice" using engineering principles in industry that have been established over a long time by some very smart people.
Would make sense...
Manifold is divided
This was my understanding
I had a twin scroll 6boost with single Tial 44mm and twin scroll T04z.
Worked mint... I also don't see the huge need for twin gates
well i have a "true" twin scroll setup on a RB2530 with twin gates, GTX35 with 6boost
I also have a Twin scoll setup for a RB2630 with single HKS 60mm on a 6boost - i havnt picked a turbo yet for this motor.
the RB2530 i should have some results within a month or so.
the RB2630 i wont have any results for at least 9months
PM me "mico" if you need an explanation. SimonR32 has just given his opinion based on his experiences. From what I remember he has his R32 GTR well sorted.
Mico - Whoever said that? If they have, they're being pretty bold about pulling the wool over your eyes - the whole point to split pulse is you are splitting the pulses and reducing exhaust collisions etc. If you have 6 pulses feeding into one collector, no amount of design is going to change the fact that you'll have twice as many high pressure pulses pushing for the same space in the same time.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
