Not a bad job, at least the angle promotes good flow, but damn its tiny. I would have gone for a much larger gate.
What is it with everyone running 38mm/40mm gates, no love for the 50's and 60's? There is power to be made there...
Here is an exhaust I worked on recently, Not an easy job but it got the results. 0.82 split GT3076. Aircon lines remain intact.
That looks so nice Scotty. Was it expensive? Looks like there would be a fair bit of work in it.
Is there much performance loss with running a single gate off a split pulse manifold with a twin scroll turbo?
Obviously it won't be as good as a twin gate setup, but do you loose much response, power or torque anywhere?
Not really, it cost him around 2 grand for the full system, plus he had intake and cooler piping made.
I would think if you can get the gate to seal the two halves a single wastegate would work just as well, as long as it was big enough and had good flow.
It is funny how people scoff as using a single wastegate on a twin scroll manifold and turbine housing without fully understanding what difference it would make. Who ever started the rumours that you needed two "or else" must be laughing and selling a lot of wastegates!
Anyway, dividing the wastegate flows right up until the wastegate (such as the photo in the link) would be much better than just merging the two flows before the gate (like on a Greddy or HKS manifold).
Yes it is in a great spot before the turn on the turbine housing to control boost very well.
6boost do a split pulse single gate manifold don't they? Has anyone tried one out?
If you are going to the trouble of buying a twin scroll turbo, I would have thought you would get a decent manifold to get the most from it rather than putting the gate off the turbine housing? I was always under the impression people only did the gate off the turbine when wanting to run external gate on the stock manifold
Edited by Mitcho_7
As the highest pressure point it makes sense to me to run the gate off the housing which is why I talked Artz into it. The idea for my setup, (if I ever get around to making it) is to get the flow straight through the turbo, cutting out the back of the scroll and making the wastegate the priority when it is open. With twin scroll just run the splitter up to the gate and the same will apply.
Too many setups I see favour the turbo at the expense of the wastegate flow which would mean too much power is lost up top imo.
The whole point of twin scroll is to work in the firing order 'pulse'.
Would make sense...
Manifold is divided
Turbine housing is divided
... that the wastegate would follow a similar premise.
Be good to see some actual information/testing/data with single vs dual with a true T/S setup to dispel - I'm assuming you have some?
I am assuming you do thinking it is undoubtably better.
You can't have evidence for everything (I see you honking that horn a lot be-littling people) sometimes it is just not feasible. You should understand that there is more "best practice" using engineering principles in industry that have been established over a long time by some very smart people.
Would make sense...
Manifold is divided
This was my understanding
I had a twin scroll 6boost with single Tial 44mm and twin scroll T04z.
Worked mint... I also don't see the huge need for twin gates
well i have a "true" twin scroll setup on a RB2530 with twin gates, GTX35 with 6boost
I also have a Twin scoll setup for a RB2630 with single HKS 60mm on a 6boost - i havnt picked a turbo yet for this motor.
the RB2530 i should have some results within a month or so.
the RB2630 i wont have any results for at least 9months
PM me "mico" if you need an explanation. SimonR32 has just given his opinion based on his experiences. From what I remember he has his R32 GTR well sorted.
Mico - Whoever said that? If they have, they're being pretty bold about pulling the wool over your eyes - the whole point to split pulse is you are splitting the pulses and reducing exhaust collisions etc. If you have 6 pulses feeding into one collector, no amount of design is going to change the fact that you'll have twice as many high pressure pulses pushing for the same space in the same time.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
