Hehe well that's different, My tyres are lined up with the guard line now so adding 5mm won't work
Got a mate wants a 10in wide on a 32 Gtr but doesn't want it to rub and doesn't want to roll the guards at all
Hey mate, I think the RE30s (the ones you like) are 18 x 9.5 +15 which means only 2mm further out on the rim, plus if you just use your tyres that youve got now it should just be the rim that protrudes slightly more, not the tyre?
These would look mad on your 32 I reckon
Yeah they are 18x9.5 +15.
Cheers
I love how this thread is a spotting, a setlist and a for sale thread all in one, haha
Simon is a good bloke I am sure he will probably let you do a test fit with one wheel. Hope your 32 is going strong or will be soon
didnt get a chance to get many good pics today as it was nearly dark by the time i finished fitting the splitter.
Heres a couple to get the idea.
the car looks alot lower now... will be sometime before i can get a coilovers due to driveway troubles..
Need to drill new holes for front number plates and respray the backing plate behind rear number plate as its faded.
Looks really good now imo.
Cheers,
Anthony
Looks fantastic mate, well done.
    • There's no way they left the factory like that. In R chassis there is nothing stopping the steering wheel being put on one spline out from straight, and then adjusting the steering arms to "correct" it (sort of). As well as the indicator cancelling there would also be an issue with how tight you can turn in one direction to the other. The other (less likely) possibility is that the "clock spring" (the circular electronic part that allows the wheel to turn while still having an electrical connection for horn and any other buttons like cruise) might not be in place correctly. I don't have any pics of the R33 (or Stagea) setup but there would be a circular locating tab which sits in the steering column to have it straight...if that is not seated properly then the indicators may not cancel at the right point (and, you might also get a HICAS error since it would think you are driving in circles)
    • It will mostly be bad scoring on the bores, which you can almost certainly fix by machining for oversize pistons. I have to say, I am super surprised that any standard turbos made it 35 years down the track before exploding!
    • Thanks for the info mate was thinking 255/35 rears and 235/40 fronts
    • What's the difference? I would have said that between the front and rear axle lines, there's no noticeable diff between a GTR and an NA 2-door.
    • It will be salvageable. It really doesn't matter what is damaged. Opening up a 30+ year old motor for a rebuild immediately means a complete rebuild of the head anyway. Damaged valves just means an opportunity to put in some nice new ones. And in the modern day, why would you not throw at least a nice set of pistons at something. And if you're doing that, why not rods, and ARP fasteners, and so on.
