I'm selling my R32 gts-t, 1989 'Type M' - 192000kms
Mods include:
-HKS2530 turbo - Checked by Hypergear and with a new compressor wheel 5000kms ago.
-Z32 AFM
-RB20 PowerFC with controller
-Bosch 040 fuel pump
-GTR injectors with ballast
-Cooling Pro FMIC
-Yellow jacket coil packs
-Adjustable cam gears
-HKS split dump pipe, through to X-Force hi-flow cat and exhaust
-Bilstein struts with Whiteline springs as sold by SydneyKid
-Front and rear whiteline strut braces
The engine mods were done about 2 years ago, built to be a track car but once I finished it I didn't have the money or time. It's only been driven approx 5000kms over these 2 years.
At the time of the mods I also put in a new Exedy HD clutch.
The tyres are near new with Federal 595's on the rear and Bridgestone Potenza Adrenalin's on the front.
The car was tuned by Ed at Autotech and was dynoed at around 215rwkw at about 17-18 psi. It is a really responsive turbo.
The gearbox is a little noisy and there are a few chips and mark as expected of a car this age, The rear right of the body kit is starting to come away slightly. Interior is pretty good except the steering wheel and a small tear in the passenger door vinyl. Has a sunroof.
Looking for around $9000 at the moment but happy to negotiate.
Call or text me on 0430-508-321 if you are interested.
Cheers,
Adrian
Edited by Kwyjibo
https://www.sau.com.au/forums/topic/389545-fs-r32-gts-t/
  • 3 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
