OK, selling my HKS 2510. This turbo is in mint condition. No shaft play, no noises. It is currently on my RB25, but it is too small and I want something bigger. Very responsive. Details are:
HKS 2510
T3
RB20 Wastegate Actuator Fitted
Brand New Stainless Oil and Water Lines
Brand New Oil Drain
Brand New Turbo Smart 90 (makes turbo line up with factory cooler piping)
Metal Intake Pipe
Brand New HKS Pod
Brand New AM Performance Dump and Front Pipe with Screamer
Everything is there for a true bolt on turbo kit. This would be perfect on a RB20. Send me a PM if you are interested. $1000.
Thanks, Scotty.
https://www.sau.com.au/forums/topic/389623-hks-2510-turbo-kit/
Hey mate, It made 230rwhp on a stock RB25DET (s15 injectors, walbro, haltech) on 10psi. Boost comes on very early (10psi under 2500rpm). Turbo is too small for what I want to do, but on a RB20 it would be perfect.
Dude are you serious? wtf is wrong with you?
this turbo flows 300PS which is 220KW at the engine...... minus the loss to wheels and max is 200rwkw if your lucky, mayb if u really crank the boost you coukld make 220. the STANDARD turbo makes 240 with no issues
This turbo was made for CA18 and SR20 upgrade, its a downgrade for even RB20 it flows exactly the same a a T28BB. what idiot would put a T28BB on their RB motor?
if you find another one you can put these on your GTR as a slight upgrade but dude you need to learn more about turbo's before u just stick shit on. dont just take the work of one retard who reccomemnds them but never actually had any experience using many turbo setups.
here take a look at this, people who actually used the turbo and the full specs of it in there too
http://www.nissansilvia.com/forums/index.php?showtopic=116238
  • 1 year later...
Standard turbo makes 240kw with no issues huh?! :blink:
Suggest you do some reading also mate :domokun:
First I've heard of a standard turbo pushing 240kw no issues. Maybe you should do some reading up yourself before spreading useless info, and ruining someone's thread. Hey I'm fairly new to SAU myself but I am led to believe this is what the pm button is for???
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
