Hi SimonR32, when the mixture map is open-the ecu must be online, right click on the map and go to properties and it gives lots of options to only show samples with more meaning, eg. how close to centre of cell, how many samples, throttle rate etc. Its quite accurate when set up. Cheers, Grant.
  • Replies 96
Hi discopotato03, there are more outputs which may or not be of use to you, the main thing apart from the direct spark is the onboard individual cylinder knock control. Cheers, Grant.
Yeah did all that, ECU doesn't have to be online. You just need a map loaded and a log loaded and it works.
Might be a little bit far off topic, but I've searched without much luck and doesn't seem worth creating a new topic.
Just in the process of wiring my AEM UEGO wideband to an input on my Link G4 plug in so that I can log my AFR's. But the Link doesn't have the AEM in it's list, so just wanted to see if someone can confirm whether I am setting up the calibration table correctly? I believe the AEM uses a linear signal; 0V = 10AFR, 2.5V = 15AFR, and 4.99V = 19.98AFR. That's according to the table in the user manual: http://www.schnitzracing.com/manuals/AEMWBK.pdf
As I understand it, calibration tables 4-6 are the linear tables in PCLink. Looking at cal table 6 which appears to be unused in mine, input value A is 0.00V and input value B is 5.00V. I set the output units to AFR. I am guessing now, that I should set the output value A to 10AFR and output value B to 20AFR? Or should I change input value B to 4.99V and output value B to 19.98V, as per the AEM calibration table? Then after it is connected, I assume I need to make sure the ECU reads the same as the wideband gauge display? And if it doesn't, adjust the cal table to suit, or?
Just wanting to make sure I'm on the right track here.
Hi Hanalado, I would start with a=0v b=4.99 In the lower section would have a=10 b=19.98. After this is done I hold the revs around 1500 and then highlight about six boxes around the current load point using the shift and arrow keys. I then make the numbers larger using the Q key until I get down to 10/1 afr and make sure the ecu reads the same as the aem. Then make the numbers smaller using the A key until you get to 18/1 afr and make sure the numbers match. It should but sometimes you have to alter the numbers a little. If you do change numbers you need to go back to the other extreme and recheck and keep doing that until its right at both extremes. Hope this helps.
Cheers, Grant.
I have a gm 3 bar style map sensor, it tends to read around 100kpa when the engine is off however there are times it is as high as 109kpa and as low as 80kpa. The fluctuation seems to be correlated with engine bay temperature affecting the sensor reading. Is any one running a genuine ac delco (GM) 3 bar map sensor? are you getting consistent readings close to 100kpa? I'm thinking of changing my sensor because this sort of variance can't be good, but no point if the same problem arises.
Cheers
Pat
Cheers
Pat
try replacing the map sensor, or check the wiring. thats not normal.
Hi, I agree with Guilt Toy most likely the sensor, should always read 100-102 kpa when not running in most of Oz. Lots of crappy copies of the Delco sensor. It could be bad earth, wiring ecu etc. but very likely sensor.
  • 1 month later...
Hi guys so I just bought a Link G4 for my R34 GTT. In the instructions it states I need to use the standard MAP sensor & just re-plumb it to a pressure source that reads vacuum & boost.
I was always under the impression they didnt come with MAP sensors. Can anyone confirm that is does & where its located?
Thank you
Are you refering to the Link ecu? If so I can confirm it is not. It states it comes with a MAP sensor IF the car does not have one from factory.
The below is taken straight out of the instruction manual
Nissan Skyline R34 GTS
The Link G4 Nissan R34 Plug-In ECU supports several options for fitting of a MAP sensor. Any one of the
following options can be used:
1. Factory MAP Sensor – The RB25DET factory MAP sensor is suitable for use. It must be re-plumbed to a
pressure source that measures vacuum and boost pressure*. The factory MAP sensor is wired to An Volt
3. The factory sensor is good for 125kPa (18psi) of boost.
2. MAP Sensor Wired Through AFM – To avoid running additional wires into the engine bay, a MAP signal
can be brought in through the AFM signal wires. The AFM is wired to An Volt 1. Refer to factory wiring
manuals for AFM wiring connections. Make sure the AFM can not be reconnected.
3. MAP Via Expansion Connector - The expansion connector provides power, ground, and analogue channels
for the connection of a MAP sensor
The R34 plug-in model doesn't come with an on-board MAP sensor.
Brody, the R34 GTT does have a MAP sensor. It is located at the back of the engine bay, above your brake lines. Like so:
Personally 18psi was never going to be enough, so I just skipped any messing around and bought the expansion harness and a Haltech 3-bar MAP sensor.
Edited by Hanaldo
Ok so I also bought a boost solenoid so I can control the boost with the ECU. I was told I can simply cut the wiring for the factory boost controller & wire it to the new boost controller.
Has anyone done this before? From memory there are 2 wires that go to the factory boost controller, which one would I use?
Thanks in advance
  • 2 years later...
Hi All,
After much of research I came across this thread.
Basically, I am having issues with my car and it is running rich . I think it is due to the boost pressure sensor or map sensor as some people refer to it .
This is a pic of it as also per earlier post. I got a qoute for a new one and it is £150 UK british pound which seems a lot.
I have seen this thread people mentioning to simply swap it with haltech 3 bar /2 bar. I am planning to do so . is it simply a rewiring and plug an play ?
has anyone done this ?
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
