Hi guys next time this is updated by a mod the c34 and 260rs section needs to be corrected. 260rsstagea , numleg , gtr260 , and big boy dan are all rs260s and need to be moved to the autech 260 list. I would love to post up some new power figs but im still waiting on my wiring harrness conversion to be finished arrrgh
Nice observation!
Might have got mixed up in the refresh. I'll go through it all tonight, and put an update together for the mods.
Thanks.
Well, I fired off a updated one to Goldzilla the mod, who hopefully will update.
Please once you see the updated one, if you believe you have a spot in there or I have missed you out, please post up. Its the only way I can keep it updated. Especially if you have C34 powers above whats listed, or Drag times would be great.
If you don't make it into the Top 5 for the section, feel free to post up results here, but the list will obviously not be updated.
Cheers.
sounds like you need a modified torque converter and it will go very low 13's pretty easily
cheers
darren
Yeh that's the next mod on the list :)
That run was a 2.311 60' time so should be a big improvement when I get it
  • 3 weeks later...
To much too long too complicated. Kiss principle.
Plus, those who know people will know the mods, or can pm if they need to.
Just thought Scotty, you have a PI time don't you?
What about Ironpaw's dual fuel setup, e85 and gas? Perhaps all the other mods should be listed too?
Mark that down. Other mods aren't really required, but the fuel gives you an idea. What % extra does E85 give you over normal, non cheater fuel?
No mate, not yet. I missed out on this weekend's run as I wasn't sure the engine would be back in. As it is it needs a damn good tune, opening up the runners made a huge difference, its now running 19/20:1 on cruise. :unsure:
Yay i finally found something i can b on a leader board for! I've done a 1:06.5 round the queensland raceway sprint track (just to be clear its not the full length national track the V8 supercars use.) only mods to my c34 were coilovers, FMIC, turbo back 3inch and gtt brakes. Hopefully now that ive made some handling adjustments i can improve on this dreadfully slow time.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
