This hasn't been updated lately, but as it stands at the moment the fastest is a 260rs with a 12.3 then Darren spencer's rs with 13.01 then my 260 with a 13.2
The fastest so far in here is 11.3...hasn't be updated for a long time
According to my Google search, a S2 C34 with RB25DET came with 173Kw at the engine. 12 years later it has 155awKw - only 18Kw loss thru the drivetrain. Is that possible, even with a manual transmission? I suspect some Walt Disney optimism at play, lol.
Nice car tho. I like them in yellow.
S2 c34 had the rb25detNEO, so 206kw from the factory.
Most stock stags lay down around the 135-150kw depending on manual/auto awkw/rwkw.
1996 s1 with a manual and a neo engine conversion.nistune, 3076r, poncams etc etc e85. just need to sort out the old girl so she holds boost, new waste spring and clean up tune under the curve and should be even better but already she is fun shopping wagon.
Sydney Motor Sport Park - South Circuit.
1:14.77 - (34*C with stock brakes and hawk ceramic pads - also overheating) lol
was good fun but took it easy on the brakes could only do 2 lap sprints before i needed to do a cool down lap as i could smell the brakes HAHA
and definately need some semi slicks rather than the federal 595's!!!
then i'd feel much more confident in the car but i learnt alot and the car handled beautifully otherwise!!!
  • 3 weeks later...
this thread needs a update
1998 Stagea 260RS
407.4 HP (303KW) @ 20PSI on caltex 98 safe daily driver tune
Congrats excellent job but she is fun to drive .
And yes this thread really needs an update lol...
Thanks mate, it definately starts to come alive with 300kw! The 4wd is starting to work a bit harder now.
When is ur's going back in for a touch up?
When i get off my butt . Bit busy with our new baby. Got to change waste gate spring and sort the boost controler out get it to hold stable then turn it up to around 20 ish psi. Also got water/meth injection to hook up basicially to lowr exhaust temps should be interesting to see what she make. Dont think my gear box is going to like it hmmm
1998 Stagea 260RS
We really really need some "more" m35s to make some power then this thread might get updated lol....... oh no did i just say that
OK, updated doc sent to mods for updating the 1st page.
some of the figures (power) weren't high enough to bump the next person off.
Remember - keep posting in here, so its easy to update when I CBF.
  • 2 years later...
  • 3 weeks later...
Well finally got round to re tuning stagea after all these years ( to busy working on customers cars ) ( and the shops s15)
Old tune 338rwkw 311awkw at 19 psi
New tune 360-370rwkw 340.1 awkw
Still the same standard neo bottom end and small 3076.63 all standard manifolds and return flow cooler , video is of Chris and my self doing a 3rd gear pull 335 awkw 4th gear is 340 awkw @27psi
  • Like 3
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
