This hasn't been updated lately, but as it stands at the moment the fastest is a 260rs with a 12.3 then Darren spencer's rs with 13.01 then my 260 with a 13.2
The fastest so far in here is 11.3...hasn't be updated for a long time
According to my Google search, a S2 C34 with RB25DET came with 173Kw at the engine. 12 years later it has 155awKw - only 18Kw loss thru the drivetrain. Is that possible, even with a manual transmission? I suspect some Walt Disney optimism at play, lol.
Nice car tho. I like them in yellow.
S2 c34 had the rb25detNEO, so 206kw from the factory.
Most stock stags lay down around the 135-150kw depending on manual/auto awkw/rwkw.
1996 s1 with a manual and a neo engine conversion.nistune, 3076r, poncams etc etc e85. just need to sort out the old girl so she holds boost, new waste spring and clean up tune under the curve and should be even better but already she is fun shopping wagon.
Sydney Motor Sport Park - South Circuit.
1:14.77 - (34*C with stock brakes and hawk ceramic pads - also overheating) lol
was good fun but took it easy on the brakes could only do 2 lap sprints before i needed to do a cool down lap as i could smell the brakes HAHA
and definately need some semi slicks rather than the federal 595's!!!
then i'd feel much more confident in the car but i learnt alot and the car handled beautifully otherwise!!!
  • 3 weeks later...
this thread needs a update
1998 Stagea 260RS
407.4 HP (303KW) @ 20PSI on caltex 98 safe daily driver tune
Congrats excellent job but she is fun to drive .
And yes this thread really needs an update lol...
Thanks mate, it definately starts to come alive with 300kw! The 4wd is starting to work a bit harder now.
When is ur's going back in for a touch up?
When i get off my butt . Bit busy with our new baby. Got to change waste gate spring and sort the boost controler out get it to hold stable then turn it up to around 20 ish psi. Also got water/meth injection to hook up basicially to lowr exhaust temps should be interesting to see what she make. Dont think my gear box is going to like it hmmm
1998 Stagea 260RS
We really really need some "more" m35s to make some power then this thread might get updated lol....... oh no did i just say that
OK, updated doc sent to mods for updating the 1st page.
some of the figures (power) weren't high enough to bump the next person off.
Remember - keep posting in here, so its easy to update when I CBF.
  • 2 years later...
  • 3 weeks later...
Well finally got round to re tuning stagea after all these years ( to busy working on customers cars ) ( and the shops s15)
Old tune 338rwkw 311awkw at 19 psi
New tune 360-370rwkw 340.1 awkw
Still the same standard neo bottom end and small 3076.63 all standard manifolds and return flow cooler , video is of Chris and my self doing a 3rd gear pull 335 awkw 4th gear is 340 awkw @27psi
  • Like 3
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
