hey mate, i have an r33 coupe and ended up getting a r33 4 door rear garnish as they have the silver 'skyline' letters on them whereas the coupe garnish is colour coded. I'm pretty sure this applies to the r34's as well. all i did was pop off the letters and stick them directly over the top of the letters as I prefer the look of the chrome letters. I just had a quick look on ebay and looks as though you would need to purchase the entire bootlid to get the letters which could be a bit costly so maybe you could try spraying or sticking chrome overlay on the letters. just an idea
Thanks Mate, here's what I'm after (see attached image)
I've been searching eBay, Alibaba, Amazon and hells knows what without any luck. Appreciate your help.
Hi Guys,
Let me know if any of you can help me. I'm after the whole chrome SKYLINE letters on R34 rear boot lid.I've been searching through wreckers and online without much luck.
Cheers
have you tried NISSAN spare parts?
They are on the rear bumper for an R34.
If you put a post up in the WTB section, maybe someone on the forums can help you out. Or try a few more local wreckers. Where are you located, I know of a few spare parts places in Sydney that may be able to help you.
As Steven said above, if worst comes to worst, you should be able to order them new from Nissan. (But as with anything direct, get ready to bend over when you see the price)
I actually have the S and Y and the E kicking around somewhere, but they wouldnt be much use to you as they obviously arent the full set. I found them in the boot of one of my GTT's while cleaning - the previous owner had removed them for the 'clean' look.
Edited by iwanta34gtr
Also important to note that the series 1 and series 2 R34 chrome letters are different.
Series 2 letters are smaller and closer together, so bare this in mind while searching.
Hope this helps, good luck with the search.
Thanks guys this helps, I am in Sydney and have been searching through some wreckers but so far without luck, let me know know if you have some shops in mind specifically. Some weeks back some one also told me to check with Nissan but told me that it may cost a fortune so I haven't checked with Nissan yet.
Cheers
1327755587[/url]' post='6208243']Also important to note that the series 1 and series 2 R34 chrome letters are different.
Thanks Mate, Just bought the whole SKYLINE from this guy for $20 bucks!
Now off to get some badge adhesive.
Cheers
Try this guy - 0410 069 096.
I've bought a few things from him previously.
He is at Wetherill Park, can be good for some stuff.
    • me too wasnt real happy and cost me a penny or 2 to replace
    • But there's the archetype for the name plate! Here's my view on that stupid TÜV ruleset. Buy a brand name aftermarket piece of equipment. In this case, the Mines front pipe we're talking about. Get it TÜV certified on the car. Damage the underside of it, say on a speed bump. Cut out the damaged section, replace with fresh metal. (For the sake of the argument only), continue doing that to the whole pipe until it is all gone, replaced with new metal. Is this grandfather's axe still the same front pipe? The design hasn't changed (much). The pipe walls are in the same places. The flanges are in the same places. It is functionally identical. How does this differ from a pipe that is ever so slightly different in fabrication (ie the number of welds in it, a few mm here and there in terms of where the pipes run, are joined, etc)? Anyone with 0.5% of a brain can see that there is absolutely no way that the performance (power, environmental aspects, noise, etc etc) of it can be any different than the genuine Mines pipe. Maybe even Mines made 2 versions of this design, with the same differences. How would anyone (say a TÜV inspector) ever be able to differentiate between them? And yet, they are so bloody anally retentive about this stuff. Mad. How upset would they be if you had the wrong spring washers on the flanges?
    • Sakura (cherry blossom) tree at the end of a path going through Kabutoyama Park in Nishinomiya, Japan. Taken with Sharp Aquos R8
    • After a fairly extensive search using Japanese terms and checking Minkara etc, I couldn't find anything even close to your front pipe in the photos. I'm no expert but the two pipes merge really close to the flange connected to the catalytic converter which is rather unique from what I've seen, which makes me think it's more than likely a custom front pipe. The welds and 'more pipe sections than usual for a brand name pipe' makes it seem like a custom one.  Here's some photos of an old Mine's front pipe. You can see that it's just 4 pipe sections as opposed to 6, and arguably looks more like a 'production' front pipe:
    • Wtb r33 low side s2 ac line
