  • 1 year later...
Thread dig
No I did not change my shafts when I swapped my 32 subframe to a 33 one.
Still work fine though you are right in saying that it is wider and it will push your wheels out.
I'm not so sure I like the look
  • 6 months later...
Another thread dig, I've nearly finished my conversion (after starting it in 2014 lol) of R33 subframe into my R32 and I'm struggling for info about the rear LCA inner bushes. There was a mention earlier that washers are required but shouldn't I be able to get R33 bushes to suit an R33 subframe?
The difference I've measured for the width of the rear LCA inner bushes: R32-45mm, R33-50mm.
I've even asked about aftermarket R33 rear LCA's and they all tell me that they're 45mm!
Any help is appreciated.
See the pics of R32 vs R33.
  • 8 months later...
12 hours ago, GTSBoy said:
HICAS notwithstanding, they are supposed to be the same "geometry".
Just bought one for $60 with all the arms and hubs (which I'm guessing I just use my R32 ones in) so will look at making some offset-offset spacers to align everything back to the middle
  • 5 months later...
Update on doing this for anyone looking to do this, parts required are:
1, R33/R34 or S14/15 subframe. (I used a R33 non-Hicas subframe, R34/S15 subframes have more gusseting, I also welded in a GKtech subframe reinforcing kit.)
2, Offset subframe bushes (I used the GKtech solid offset bushes, these mount the subframe up a lot higher which is better for roll centre and will require a little "massage" of the floor pan on the front on either side of the subframe, test fit the subframe before mounting the diff and arms on it.....all will become obvious)
3, R33/S14 lower suspension arms (you can still use the R32 arms but will need spacers/washers to pack out the difference on the inside mounts
4, R32 upper arms (I made the mistake of buying brand new R33 top arms thinking they would be required.....but they foul on the shocks)
5, Driveshaft Spacers (I used the GKtech 10mm ones. There is some differing thoughts as to whether these are required, but I figured if the R33 subframe is 10mm wider on either side then I would put them in to avoid damaging the CV joints)
6, R33/S14 Tie Rods and Bushes (If you are getting rid of the Hicas by going to a non-Hicas subframe like I did you will need these and something like a set of Whiteline bushes to replace the ball joints that are in the hubs for the Hicas tie rods)
7, R32 ARB (seems to still fit, the mounts are spaced a little further apart)
Edited by Sub Boy32
  • Like 1
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
