Hi Guys/ Gals
As per title says. i'm looking to see if any R34 GTR owners would like to do a straight swap with cash my way between my ARC Airbox and a Stock Airbox
NSW only
PM me for further details, Pic is below.
Cheers,
Will
how much just for ARC box without swapping?
I've checked online and they seem to be going between $600 to $800 mark new and used.
I'll be asking the $600 mark for this airbox if i can source a stock airbox.
Pity Will; we gave away the OEM airbox and snorkel (air intake) to the buyer of the last R34 GT-R we had (with pods). ;)
I have a snorkel only f/s, if you can find the remainder of the box.
You were enquiring about my Nismo Calsonic 3" exhaust system too through Matt, and I don't have a sound vid of it at all.
I'm not even sure if you're still after a Nismo system.
You're most welcome to come up and try it though = try before you buy.
PM'd
I was thinking of getting one of these, currently have pods on mine and stock ones sitting in a box.
Am looking at putting the stock ones back in but thought about getting these.
Can I ask why you want to go back to stock ones?
Cheers,
Anthony
Cheers,
Anthony
Anthony, i'm planning to engineer my car, ARC box will not pass
Cheers,
Will
Too easy,
I'm planning on doing the same and thought that these would be legal, but if not I will look at putting the stock ones back in.
Thanks for the info, and sorry I couldn't help.
Cheers,
Anthony
Too easy,
Cheers,
Anthony
Alls good :)
According to the Nismo Catalogue, this Nismo air intake is supposed to increase airflow by 15% over the standard snorkel.
Thanks Terry, i'll look into this
Nismo intake looks like it has a lot of clearance below it for the radiator.
Might be what i'm after.
But "might" is hard to buy for.
Yes it's gapped to accommodate the rad but any aftermarket rad that's wide, won't fit.
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
