Hey all have some parts sitting around after my rebuild.
A lot of parts good for any rb engine.
All parts came off working and in good condition
the list:
4x 265/35/18 nankang ns2 tyres, have camber wear on the fronts, tyres good for texi or skids $250
Standard BCNR33 radiator came off car when i bought it 107xxxkms $150
Std rb26 cam gears $35
Std GTR fuel pump good upgrade for rb20 $70
Std rb26 turbos no real shaft play evident in good condition just dirty from gasket leak $400
Std rb26 manifolds had plans to port for new setup but change my mind $70
Std BCNR33 dump pipes $50
Std Rb26 top feed injectors with resistor pack, good upgrade for rb20 $130
Std Rb26 water pump was put on car when 100000kms service was done only 25xxx kms on it still looks new $100
Std Rb26 AFMs with plugs $120
BCNR33 HICAS unit $100
Nismo top feed 600cc injectors only used for 10xxxkms, were cleaned and flow tested when bought off another forum member, work perfectly fine supports well over 330kw $650
BRAND NEW Tomei 87mm x 1.2mm head gaskey only test fitted to check clearances $270
Prefer NSW pick up, located sutherland shire
but can post at buyers expense
contact by PM on here thanks
post-71236-0-54912700-1327806937_thumb.jpgpost-71236-0-82659100-1327807326_thumb.jpgpost-71236-0-76591500-1327807315_thumb.jpgpost-71236-0-80426000-1327807301_thumb.jpgpost-71236-0-72386200-1327807284_thumb.jpgpost-71236-0-70669900-1327807272_thumb.jpgpost-71236-0-54912700-1327806937_thumb.jpgpost-71236-0-79044800-1327807357_thumb.jpgpost-71236-0-08414600-1327807374_thumb.jpgpost-71236-0-21700600-1327807387_thumb.jpgpost-71236-0-67286500-1327807402_thumb.jpgpost-71236-0-40953800-1327807421_thumb.jpgpost-71236-0-92721900-1327807447_thumb.jpgpost-71236-0-52610600-1327807474_thumb.jpgpost-71236-0-78018400-1327807484_thumb.jpg
https://www.sau.com.au/forums/topic/389767-r33-gtr-parts-and-others/
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
