Hey all have some parts sitting around after my rebuild.
A lot of parts good for any rb engine.
All parts came off working and in good condition
the list:
4x 265/35/18 nankang ns2 tyres, have camber wear on the fronts, tyres good for texi or skids $250
Standard BCNR33 radiator came off car when i bought it 107xxxkms $150
Std rb26 cam gears $35
Std GTR fuel pump good upgrade for rb20 $70
Std rb26 turbos no real shaft play evident in good condition just dirty from gasket leak $400
Std rb26 manifolds had plans to port for new setup but change my mind $70
Std BCNR33 dump pipes $50
Std Rb26 top feed injectors with resistor pack, good upgrade for rb20 $130
Std Rb26 water pump was put on car when 100000kms service was done only 25xxx kms on it still looks new $100
Std Rb26 AFMs with plugs $120
BCNR33 HICAS unit $100
Nismo top feed 600cc injectors only used for 10xxxkms, were cleaned and flow tested when bought off another forum member, work perfectly fine supports well over 330kw $650
BRAND NEW Tomei 87mm x 1.2mm head gaskey only test fitted to check clearances $270
Prefer NSW pick up, located sutherland shire
but can post at buyers expense
contact by PM on here thanks
post-71236-0-54912700-1327806937_thumb.jpgpost-71236-0-82659100-1327807326_thumb.jpgpost-71236-0-76591500-1327807315_thumb.jpgpost-71236-0-80426000-1327807301_thumb.jpgpost-71236-0-72386200-1327807284_thumb.jpgpost-71236-0-70669900-1327807272_thumb.jpgpost-71236-0-54912700-1327806937_thumb.jpgpost-71236-0-79044800-1327807357_thumb.jpgpost-71236-0-08414600-1327807374_thumb.jpgpost-71236-0-21700600-1327807387_thumb.jpgpost-71236-0-67286500-1327807402_thumb.jpgpost-71236-0-40953800-1327807421_thumb.jpgpost-71236-0-92721900-1327807447_thumb.jpgpost-71236-0-52610600-1327807474_thumb.jpgpost-71236-0-78018400-1327807484_thumb.jpg
https://www.sau.com.au/forums/topic/389767-r33-gtr-parts-and-others/
  • 3 weeks later...
