Hey all have some parts sitting around after my rebuild.
A lot of parts good for any rb engine.
All parts came off working and in good condition
the list:
4x 265/35/18 nankang ns2 tyres, have camber wear on the fronts, tyres good for texi or skids $250
Standard BCNR33 radiator came off car when i bought it 107xxxkms $150
Std rb26 cam gears $35
Std GTR fuel pump good upgrade for rb20 $70
Std rb26 turbos no real shaft play evident in good condition just dirty from gasket leak $400
Std rb26 manifolds had plans to port for new setup but change my mind $70
Std BCNR33 dump pipes $50
Std Rb26 top feed injectors with resistor pack, good upgrade for rb20 $130
Std Rb26 water pump was put on car when 100000kms service was done only 25xxx kms on it still looks new $100
Std Rb26 AFMs with plugs $120
BCNR33 HICAS unit $100
Nismo top feed 600cc injectors only used for 10xxxkms, were cleaned and flow tested when bought off another forum member, work perfectly fine supports well over 330kw $650
BRAND NEW Tomei 87mm x 1.2mm head gaskey only test fitted to check clearances $270
Prefer NSW pick up, located sutherland shire
but can post at buyers expense
contact by PM on here thanks
post-71236-0-54912700-1327806937_thumb.jpgpost-71236-0-82659100-1327807326_thumb.jpgpost-71236-0-76591500-1327807315_thumb.jpgpost-71236-0-80426000-1327807301_thumb.jpgpost-71236-0-72386200-1327807284_thumb.jpgpost-71236-0-70669900-1327807272_thumb.jpgpost-71236-0-54912700-1327806937_thumb.jpgpost-71236-0-79044800-1327807357_thumb.jpgpost-71236-0-08414600-1327807374_thumb.jpgpost-71236-0-21700600-1327807387_thumb.jpgpost-71236-0-67286500-1327807402_thumb.jpgpost-71236-0-40953800-1327807421_thumb.jpgpost-71236-0-92721900-1327807447_thumb.jpgpost-71236-0-52610600-1327807474_thumb.jpgpost-71236-0-78018400-1327807484_thumb.jpg
https://www.sau.com.au/forums/topic/389767-r33-gtr-parts-and-others/
  • 3 weeks later...
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
