G'day all
I have time off work to finally take my "finished" R34 down the quater on 15th Feb so thought I'd see if anyone is interested?
Let me know for those interested in meeting up down there.
Would be great to get a group of skylines to try and put a few V8's back in their box ;-)
http://www.motorplex.com.au/news.php?newsid=788&g=9&pg=drag
Cheers,
Brendan
https://www.sau.com.au/forums/topic/389809-wednesday-night-drags-15-feb/
  • Replies 44
yeah I'm just about ready for another blast.. payed for the SS license so might aswell get some runs out thumbsup.gif
come on there must be more peeps that want to race and see what their car can do ???
Here, here Richard!
Look forward to finally meeting you and hearing that 33 roar!
Surely we can get a good turn out this time - come on people it's not about what time you do, it's about getting amongst it, making some beautiful RB noise and having some fun in my opinion!
Here, here Richard!
Hmmmmm very tempting fellas, new clutch is now bedded in so might try join you two :yes:
Cool...
if its not bedded in properly know, it will be by the time you drive home on wednesday thumbsup.gif
Baaahhhh! Always bad timing! Car not quite ready yet - but I'll come down with some Pom-Poms and support the team!
Just finished installing the new suspension and tidying up a bit so I'm good to go ;-)
Look forward to catching up/meeting you all there fellas!
Wes - you and I have much goss to catch up on
Edited by Bren444
I hope its a nice soft set-up to allow it to squat.
rich's gtr has a very sexy roar to it you will not be disappointed to hear it. i need a new flywheel and clutch kit for one car and basically a motor rebuild on the other
Thats a bugger Michael, I have a couple of worn-out clutches in the shed, one has the standard flywheel if you are wanting one...?
And Matt, is there a Tutu with those pom poms :woot:
Well I've raised the rear height and it's on the softest setting but it's still pretty stiff so see how it goes.
I already had a bilstein sports kit which I've just replaced and that was a pretty good set up so I don't think there will be a huge difference with the race kit.
Might see if I can tee up a skid switch between now n then so I can practice doing warm up skids!!!:D
Pretty sure warmup skids are only of benefit if your running drag rubber unsure.gif somebody correct me if I'm wrong,
from my experience, once normal road tyres are hot, the grip goes down hill..
yep this has been my experience, especially on the track, once hot they are useless, heres what I found after a bit of Googling:
Burnouts are traditionally used to warm up a car’s tires before a drag race. Warming up the tires makes the rubber softer increasing traction and also cleans the tires of road debris like gravel – further increasing traction. Slicks or drag radials are needed for a burnout to have noticeable results on the track, as burnouts using street tires do little more than make smoke and destroy rubber.
All depends on many things.. Try it with and without, you normally get enough runs to try a few different ways of doing it. Personally I liked ~20psi in my tyres and a little spin, but then it was just good fun too. :D
As much as I would like to get back down there since the rules have changed, unfortunately my car doesn't want to hold power steering fluid anymore.. just one more thing to fix.
Yep the fun bit, that's the key to me :rofl:
Have managed to fit one up tonight, so will be doing skids for fun whethers theres benefit or not! Looking fwd to it.
Brendan you can do warmup skids matey - no excuse!
http://www.motorplex.com.au/media/docs/STREET_REGULATIONS_Final_291111.pdf
Street cars originally fitted with four wheel disc brakes and air bags can now go down to 10.00 without the loop, licence etc. Looks like my 32 can go down to 10.50 same, no airbag. Before it was lower than 12.00 that I was asked to leave.
Hell yeeeeeeaaaahh! baha I am all about making RB noise my friend ;-)
I'm hoping you fellas will be impressed with my new exhaust set up - It's the loudest non GT-R I've heard without an external waste gate.
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
